#41
Tell the engineers to eject the core and then detonate! Maybe the blast will knock us clear… repeat eject 1st, then detonate
#42
What, no instrumentation to view water level, input voltage, or boiler pressure?
#43
How do adjust timing for tamp, grind and bean moisture content?
_______ Brian '71 T '72 E '80 Weissach SC '94 C2 '05 996 GT3 CUP '09 White Winged Cayman S (Hers, all hers!) '11 GTS/C4S Donuts '15 Boxster S #Blubyu |
#44
tamp should be constant (Jazz probably has one of those calibrated tampers, as he is quite OCD ); you adjust the grind to take into account the 'moisture content' -- that's why you time the shots in the first place
#45
Without an engineer I must watch each pour and adjust my timing based on flow rate and creme coloring. But I want one of these timers And a double boiler.
#46
OK, some simple logic for the over-zealous among us:
Espresso = Italian Italian =/ consistent If you're looking for perfection, aim higher than your coffee cup. Besides, sometimes there is wonder and even discovery in the imperfect. Yeah, I should know, right?
#47
Grind, bean mass, tamping pressure and moisture content are four variables. But it's pretty well accepted to keep tamping pressure constant (although I do vary it slightly if I over/ undershoot bean mass), and there is usually a set recommendation from the roaster on bean mass. The grind courseness/ fineness gets adjusted as the beans dry out and start to go stale, so you adjust the grind to keep the shot time within a recommended range. Geeze, you need a Sicilian wife so you can learn stuff like this...
#48
Tamp is consistent, so you adjust your grind to account for bean content to stay in the 30s range. Quote:
#49
whats a good starter kit for the amateur espresso enthusiast?
Lane '93 RS America | '03 M3 | '02 325iT | |
#50
This one seems to have good reviews.
