Replacing a trombone with a proper oil cooler. - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Replacing a trombone with a proper oil cooler.
Old 09-26-2021, 08:28 PM
Default Replacing a trombone with a proper oil cooler.
Replacing a trombone with a proper oil cooler. The car already has slightly later fenders so that helps a bit.
First thing I like to remove the entire oil cooling loop together. This way I can work on the often hard stuck fittings with room and no chance of dinging some paint. Soak all the fittings with the penetrating oil of choice, wait a bit then heat the nuts. Once good and hot crank on the nuts. If stuck I like to load up the wrench and hit the wrench handle with a slugging hammer a time or two. No go? More oil and more heat. Not more torque which can strip off the thermostat housing threads. Repeat as needed until it comes loose. Super stuck and replacing the line? Jump ahead to the finish and cut the nut with a dremmel and a cut off wheel. As you can see someone cut a lock ring nut off at some point and made a mess of things. The housing and fitting boss were damaged but not leaking.
Drain the lines and if dirty, covered in paint and undercoating and you care about such things blob on paint stripper and wander off to work on the mounts.
Next is to measure up for the cooler mounts. There is a top and a bottom mount to add. I like to line up the top mount, tack it in then hang the cooler to line up the bottom mount. The bottom mount never ever fits right and you will need to do some fitting and bending. Use the cooler to show where it goes. Clean up the metal, tack then weld in. Take care not to dump too much heat into the metal at any given time. You can set the paint in the front trunk on fire. Clean the metal and weld in. Coat with seam seal and done for now. Will coat with undercoating once the seam seal dries overnight.
Next up is fixing the dented up brass lines
Old 09-26-2021, 09:48 PM
Your work is sloppy as always
I wish the 914 had enough space to put a cooler in front of the wheel wells
Would be perfect for your old core engine getting built up (finally).
'73 914 2.0 (2.7/6 conversion in progress)
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
Old 09-27-2021, 02:11 PM
Cleaned up the lines with paint stripper. Flushed out the oil and plugged the ends. Pressurize to about 80 psi and heat with a plumbers torch. Like magic to watch the dents slowly come out. Sharp creases get a little gentle help via the slip joint pliers using the flat part of the jaws. Heat and wash the dents with the flame take your time and check the pressure now and then. The dents came out real well on this set.
Clean and sand off the rough bits and coat as desired. In this case it will be satin black. Was some conversation about shining them up but the metal has too many deep discolorations. Could buy new ones for the sale labor cost.
Beans the border collie black lab puppy picture has nothing to do with this project . It was in the same folder as the rest and it make me smile.
Old 09-27-2021, 10:39 PM
Lines clean inside and out with a nice coat of paint. Welded in brackets seam sealed and a first coat of undercoating.
Next up is hanging and assembling everything. Sounds simple except for the part where Nothing Ever Fits right out off the box.
Old 09-28-2021, 06:13 PM
Ok time to cram it all back in. I spent some time dressing and cleaning up the new thermostat fittings and existing piping threads and ring nut threads. The thermostat fittings have soft, fine threads and they are very easy to bugger up. I like to make sure all work smoothly before they go onto the car. Hung the oil tubing and fit the thermostat to the tubing in the real wheel well. Got things lined up then went back and snugged everything up.
In front it is easiest to install the upper isolation mount then put the cooler, fittings, screen, lower rubber isolation mounts and gaskets together on the bench. Install a thermostat switch if a fan is to be added and a plug if not then present the whole thing. Once in install the short flex lines, adjust everything as needed and snug things up.
Next is air flow
Old 09-29-2021, 11:09 AM
hoophead's Avatar
hoophead hoophead is offline
hoophead
What do you use to tighten the fittings on the thermostat, in particular the forward-most lower? I "customized" a 12pt 36mm socket by cutting a pipe-sized slot cut in the side and then welding a rod on the side, perpendicular to the axis, to use as a lever. A hose clamp is needed around the whole circumference to keep the socket from flexing.
Jeff S
'09 987.2 Cayman S
'03 986 Boxster Base
'13 958 Cayenne GTS
'11 997.2 Carrera S Cab
'05.5 Audi S4 Quattro
'13 Audi TT-RS
'18 Audi Q3 Quattro
'20 GMC Tow Beast
Old 09-29-2021, 11:27 AM
Cairo94507 Cairo94507 is offline
Cairo94507
That is a very clean looking install.
'71 914-6
'17 Macan GTS
'16 Audi S3
Old 09-29-2021, 11:47 AM
tomfree tomfree is offline
tomfree
Came here for the killer resto work...left wanting to pet the pup.
Tom Freeman
Coming soon '87 951 w/ LS |'21 Q5 PHEV (DD, dog hauler)
'16 Vulcan S
Old 09-29-2021, 12:22 PM
A wrench. I install the lines in a back to front order so they don’t get in the way of the next line being tightened.
Old 09-29-2021, 04:28 PM
Very nice work.
18 GT3T -
04 996 GT3 - HPDE
96 993 C4S -
Sold: 11 997 C2S, 86 951, 14 911-50, 79 911SC, 74 914/6, 11 997.2 C2S, 88 944, 16 GT4, 13 Boxster, 1973 914/4 2.0, 1980 911SC ROW w/3.2, 77 911S Targa, 1970 914GT 3.2, 71 914/4 2.4, 76 912E, 89 944S2, 1980 924 Turbo, 98 Boxster, 70 911T, 72 914, 75 914, 73 914, 87 944, 74 911, 72 914 - 08 535i, 97 M3, 06 M3, 95 M3, 98 328is, 95 530i, 95 328is
