Miscellaneous Discussions Off Topic (OT) items that really don't fit into any other Category |
I've had this Makita saw for probably 30+ years. The lever that locks the cut depth adjustment in place won't tighten down unless I rotate it 180 degrees clockwise from where it is sitting now. That doesn't do any good, because then the cut depth is zero.
Anyone have a clue how to fix this?
John Clay 2011 Cayman 1986 944 "Traffic Cone" 2013 Scion FR-S |
Hi John - I'm guessing that the locking mechanism has been goofed up since you've owned it?
A buddy of mine who does woodworking has the following to say: Quote:
ed 2016 GT4 2005 Lotus Elise 1994 RX-7 R2 |
John,
Is there a grommet or bushing that may have deteriorated and fallen out that may have been what allowed tightening of the lever, without the bolt going all the way down.
- Tony P. Currently - 1984 944 SP2 racer - 1977 911 KM Special vintage racer - 2012 Cayman R (also the wife's) - 2000 Boxster S (now mine) - 1995 993 (garage queen) - 2007 Cayman S (wife's track beast) - 2017 F350 (tow monster) - 2018 Jeep Wrangler Gone but not forgotten - 1989 944S2 - 1979 RX7 - 1986 944 - 1991 944S2 (in car heaven...) - 2001 Chevy Suburban 2500 (FIL's beast now) |
Ive had to swap bases on my old skil saw when the mag base broke. The thumb lock on mine is just captive to the nut that tightens the adjustment. You should be able to pull it apart reclock the thumb lock to where you you like. I would agree that a bushing/washer that rides along the rail may have been lost as the lock should move 90 Deg before it tightens.
Current 07 Mini Copper S 99 Dodge Viper ACR 65 Shelby 427 SC 07 Ducati 1098 17 Alfa Giulia Quadrifoglio Projects 86 "Backdate" 911 2.8 RSR 73 911 T Targa (Sold) |
Lol, I ran into this same problem on my Mikita saw yesterday. It locks fine with higher angles, just not when at “0”. I’m going to put in a shimming washer (if I can get the nut off!) we’ll let you know if that works.
- John ‘00 Porsche 996 C2 '72 BMW 2002tii '92 SCCA SSM (sold) '80 SCCA SRF3 (sold) '89 Porsche 944 (sold) '59 Porsche 1600S (long gone) |
It looks like you are missing the guide? See my saw - 810 mm Makita
John B 79 930 87 951 (sold/engine in wrong end) 86 911 Targa (sold/missed) |
Remove the small screw that holds the tear drop shaped plate. Turn the nut 1/6 rotation tighter. Reinstall the teardrop plate and screw.
![]() Quote:
![]() ![]() ![]() Run upstairs, fix my saw, eat some lunch, back to work. All in 15 minutes.
