BMW Technical Discussions BMW related technical discussions and questions go here. |
Mostly over-heating of both the pads (melting) and fluid. People do get by as mentioned but bleeding them after ever session or every day. In my case I must of melted the fronts. I think the e46 spec series requires their use but those cars are maybe 500 lbs lighter and 120hp less.
Proper ducting helps too, I run the Hard motorsport kit on my SE46.
www.hardmotorsports.com
95 993 16 GTI 02 BMW Spec E46 #27 01 Boxster 86 944- AER/Chump #33 20 F250 Tremor |
Paddy
Yup - that is the only reason I let the dust shields on. That and I did not want to take the bearings out and apart. |
Updated pic showing the brake line connections and fittings.
