you know what makes our hobby look cheap? - Page 47 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » you know what makes our hobby look cheap?
Old 04-23-2019, 08:27 AM
Dandelion's Avatar
Dandelion
Originally Posted by Jabs1542 View Post
I have a spare amp and preamp you can borrow. Hafler DH-220 amp, Carver pre amp (CT-27V).
My money is on the amp. Have you noticed it dropping out to particular music (thinking speaker load)? Room temperature? Power grid? I looked up your amp (nice amp, good pick) and see it doubles at 4 ohms so dropping impedance shouldn’t be a problem, but the 2 massive torroidal power supplies may be strangling your power grid - no power conditioner for the amp, correct?
Hi Jay - the dropouts (confirmed again last night after shuffling interconnects) are mainly during relatively quiet parts - e.g., dialogue during movies, etc. With action scenes or playing music (i.e. under higher load), not as much.
BT - I also swapped to the Active outputs on the pre-amp - no change in behavior.
FWIW, I do have a power conditioner (API Power Wedge - another 20 YO vintage).
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 04-23-2019, 10:18 AM
Originally Posted by Fumes View Post
Dear Dorki HiveMind,
I have a Project basic turntable and need a reasonably priced but loud and decent sounding setup...speakers, tubes, and such....suggestions? Call the budget 3k ? Am I insane?
Thanks in Advance!
I will sound like a broken record - check out Brett's used / vintage gear at Hifi Heaven and Command Performance AV both located in Falls Church.
Old 04-25-2019, 10:33 PM
Dandelion's Avatar
Dandelion
Thanks to Jay for the loan of a couple pieces of equipment. It's the power amplifier.
Off to shop for some new kit.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 04-30-2019, 08:26 PM
Dandelion's Avatar
Dandelion
Ended picking up a PS Audio Stellar S300 power amp. This is a hybrid - class D with a MOSFET class A input stage, built on a pair of ICEpower modules which can drive 300 WPC into 4 ohms.
The low pass filter for the class D section rolls off at 50kHz.
VERY impressed so far - very listenable right out of the box with great detail and sound staging.
Unless something goes drastically wrong I’m probably hanging on to it.
Ed
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 02-28-2020, 04:25 PM
Command Performance Audio in Falls Church is taking on Burmester gear. Very blingy!!!
Old 02-28-2020, 04:41 PM
#polishforprez
That $tuff is pricey! Pretty nice gear, though.
- 2020 quickly disappearing...
Old 03-02-2020, 03:19 PM
Charlie Stylianos's Avatar
Next project is to build an updated version of the chip amps mentioned here. New version uses dual EC7293's producing 60wpc/8ohms or 120wpc/4ohm.
https://youtu.be/tmQdHv_glcY?t=123
Will probably be getting rid of the 50wpc PP monoblocs I built a couple years ago if anyone is interested.
Kyriakos E. Stylianos
Baglama inspired
Old 03-02-2020, 04:27 PM
edevinney's Avatar
Most Courteous Driver
Location: On the broad, majestic Shannon. And Lincoln VA.
edevinney
The chip amps look like a very interesting rabbit hole to go down... https://spectrum.ieee.org/consumer-e...-sort-of-cheap
Purcellville
993 + Boxster S + Eurovan MV + 4Runner
Old 05-22-2020, 09:42 PM
edevinney's Avatar
edevinney
After doing some research I bought a 3e TPA3251-based amplifier board. 100+wpc at tiny distortion and reviews said the sound was good, so our trade deficit is down another 70 clams to China.
The IEEE article called for a linear power supply, but most folks who build find that a switching power supply works well, so picked up a Meanwell 24vdc switcher. Everything came in this week and I couldn't resist cobbling it together to listen.
Net result: damn fine sound, accurate and fast. The little (4"x4") board didn't break a sweat at enthusiastic levels through Kef104/2 speakers which can be a challenge to drive.
Extra damn fine for $100 in parts - the case and face plate will cost more. Watch for a pair of Bryston 2b-lp pro amplifiers in the for sale forum soon...
Purcellville
Old 05-24-2020, 09:42 AM
The photos on the IEEE site (which I've kept open planning to do what you did) don't show a heat sink. Did you buy that separately or did it come with the board? Was the switching power supply a money issue or a quality one (the toroid transformer looks cooler, but probably makes the amp much heavier)?
IndexFingerRacing.com
2009 911 C2S Coupe "The Green Car"
2016 Toyota Highlander (wife's DD and my new tow vehicle
2006 Dodge Durango - sold to a Dorki
2003 Acura MDX - Just shy of 200K
86 Black 911 Coupe race car (owned 2010-2016)
86 Gold 911 Targa (owned 1998-2012)
82 WineRedMetallic 911 Targa (owned 1986-7)
