#71
Advantages of half rotate pumps are additional possible regulations.
In normal piston pump, we have two elements definition pumps – diameter of piston and stroke piston In half rotate pump we have too same elements: diameter “piston” and long “piston” and additional important possible regulations TORQUE of drive pump on arm with some hole... This same on crankshaft side This regulation are without additional gear . For salt water I think better solution made aal this pump PCW , or ABS, or propose - ceramic Regards Andrew |
#72
Without any cogged gear .Last I don't prefer cogged gear.
Animation drive truck without any cogged wheel. Rod differ, two clutch ( maybe hydraulic)and half rotate engine ,same parameters "Hercules C130" - Vintake= 250 liter. Without any gearbox. For truck are good parameters. Regards Andrew |
#73
#74
the differential is powered by jiggawatts. duh
#75
only your rod is powered by jiggawatts
#76
that would be millijewels
#77
....but I wonder if the dual clutch system allows the L & R wheels to operate independently. For example, when turning left, the left side clutch disengages, allowing the left side wheels to freewheel and speed up.
#78
My grandfather worked as engineer on railroad .......
Unfortunately, it has died before I have been born .. Andrew |
#79
#80
What is this?
This is a hydraulic pump of widmill Manner of utilization is next my proposal instead of mechanical transmission in producing windmills electric current :Hallf Rotete Pump Main principle of operation on following drawing and has enclosed animation Solution has many advantages from haf rotate pump. Expensive substitute is first most important and noisy, emergency transmission of mechanical windmill . It is presented next advantage on former drawing for one dynamo driven manner of connection of whole farm of windmill hydraulic engine serious too. This way, we save several most expensive elements of windmills, treating such farm windmill as integrity .( Complex design) Regards Andrew Santa Claus |
