AC Repair
Contemplating removing the AC from my car. Every spring it takes $$ to get it going and it never worked great even after the conversion. Maybe I am taking it to the wrong place. Any recommendations on where I can have the AC looked at before I decide to chuck it.
Thanks, Chris 89 Carrera
Chris M 73 911 E 89 Carrera |
Have you tried Autobahn? I know they work on AC. They recharged mine after my condenser was damaged.
Good luck getting the A/C in an '89 working in a manner that is acceptable by today's standards. The only real way to do that is to swap out with an aftermarket system.
Before removing mine >10 years ago, I contemplated adding a third condenser (which works great in less humid environments, I'm told). But if you're going to do that, you need to put in more modern hoses that won't slowly leak refrigerant (that should save you from the annual costs). Also, it just doesn't blow as cold without R12 for which it was designed.
Peter (not "Pete") K. 2016 Cayman S 1999 Miata ("SM") race car 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa Last edited by Dr K; 04-03-2020 at 10:11 PM. |
Chris, gave up mine, in a black interior, years ago due to leaks somewhere in the miles of tubing!
I am going to put the belt back on and see what happens. If it costs more than $200 to get going I am going to take the compressor and mount off. Will try to mothball the rest.
Chris 89 Carrera
