#81
Continue:
I had this 993 heat cross over pipe still attached to the engine as I had it installed in the 84 Targa as a loaner, until I needed it back for the 71. The long hood rear bumper just don't have enough space for anything, especially with the 3.6 and still having the 964 engine console. I got this GT3 muffler and it was the plan to use it for the 71 together with the 3.6 engine. This will be a future project to implement it, and I decided to take a different way for the time so I can finish the car. With the heat cross over pipe removed, I use a Magnaflow cross muffler I had and made some connection pipes from the 993 heat exchanger to the muffler. I made the exit below the bumperettes. Here is it all fitted and finish welded. I blasted and Cerakoted the whole thing except the end pipes. This will do for now. Back to the Frunk area. Installed the gas tank and some other bits and pieces. Finally mounting tires on the finished wheels. It still sits a little high, but that will be adjusted during alignment. So I had to make some linkages for the door pulls. Here temporarily with black pulls which will be replaced with another color. First door panel is done. Also finished the gas door and make a protective flap from leather. Why not ? Since I like my frunk line so much I did on the other 2 cars, I could not leave this alone. The hood got a custom crest. Finally time to do the alignment with the new setup I made last year. Finishing the doors. Also finishing the rest of the dash and interior. Here are a few more pictures. Cheers Engelbert
LED Lights for Classic Porsches 2012 Boxster S 2006 Cayenne S 1984 911 Targa, 3.4L 1982 911 SC 1978 1303 Kaefer Cabrio 1971 911 3.6 1966 912 - Future Project |
#82
Love it. Doing your own welding? Tig? What tires are those?
Chris 1987 928 S4 - Turbocharged w/ ~600 TQ/WHP, Front/Rear big brake upgrade, MegaSquirt, and a few other things. |
#83
Yowzer
'64 356 SC '73 914 2.0 (2.8/6 conversion in progress) '65 Falcon 80 ‘19 SQ5 Gone but not forgotten: '02 S6 Avant - trans blew, but rebuilt as a 6-speed by new owner '99.5 A4 2.8QT - tree fell on it after 20 years ‘74 MB 280C - traded for paint/rust repair/6-conversion mods on the 914 |
#84
You. Are. My. Hero!
Question:With the exhaust tips so close to the fiberglass rear bumper, isn't that going to burn the fiberglass?
Peter (not "Pete") K. 2016 Cayman S 1999 Miata ("SM") race car 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa |
#85
I do MIG welding.
The tires are Falken RT615, 225/45 and 265/40 on 17 x 8 and 10 wheels. Cheers Engelbert
#86
Cheers Engelbert
#87
That's typically what I say right after using 50 zip ties to hold some critical-ish part in place for the next five years.
Good grief this is beautiful work. And I love the key!
John P. 1994 968 - DD 1984 944 NA - Low income housing for mice / Lemons Car Past: 1986 951 - sold 1987 944 S2 Conversion - sold 1989 944 NA - sold 1986 944 NA - donated |
#88
I did a few little things on the green 911. I made a label for the custom fuse setup, also labeled the relays. I installed the windshield washer tank, and made new aluminum door lock pulls.
Here are some pictures: Cheers Engelbert
#89
meticulous work (as always!).
what's 'Fasher'?
David D. '87 Targa - 2024 is the year, beeches... |
#90
Turn signal flasher relay, and High beam flasher relay. These are normal located behind the dash. I relocated them to the fuse box.
The 71 has original only the horn relay next to the fuse box. See image below. Cheers Engelbert
