#601
That's right, but you can always buy a German product at home, which is the 3rd type of energy on Earth .. And the one who set the law is Lord Kelwin, who thought that birds fly because it is a divine matter ... But that's nobody this sharp view of reality bothers and many repeat it ...
But here is this German idea ... Andrew |
#602
This German idea works or doesn't work, but certainly when applied to my balloons it shows the way to go .. My balloons are not perpetuam motion, just a giant heat engine for low temperature, which has already been proven to work because the balloon is rising due to this relatively low temperature inside.
And this German way how to properly enlarge it, it will work, enabling the previously wasted energy released into the air to use, and it can be energy released into the air from a coal-fired power plant, gas-fired power plant, or four-stroke energy engine (atomic power plants also), which only have no more than 50% efficiency, and the rest they release into the atmosphere And now maybe even with 40% of this energy can be used for electricity production, which can even give 90% of the total efficiency to give us such a new power plant ...* Well, such "balloons" would have to have dimensions of 10 x 20 x 10 meters, and they could be built like scenes at outdoor concerts .. but the skin weight would be balanced, as well as thermal illumination in the form of foam polystyrene lining could be done .. No only the height of the tower is a problem .. Al I think that the height of 200 meters is quite real, that is, say, these 6 pieces of such "balloons" on this tower could work on one side, which would give a pull of up to 3000 KG .. Well, for example, exhaust fumes from a diesel power plant could be introduced there, and with cooling hot water too .. So theoretically 50% of this heat energy lost in such a power plant could be forced to work ... Even water vapor could also be used to fill a "balloon" .. its weight is only about 0.5 KG at a temperature of 80 degrees Celsius .. hot air pump, e.g. power plant chimney ... and works 24 hours a day regardless of the weather .. Andrew |
#603
Interesting properties of such an engine .. At a tower height three times greater, we will also receive 3 times more torque on the power output shaft, while we provide the same amount of heat per second....
What if the 10 ray tower was ...? it will also be 10 times more energy ... The only limitations are the realities of technical possibilities .. But theoretically, the energy received can go to ... infinity ... Interesting.. Andrew |
#604
Wuzak, on 12 Feb 2020 - 06:31, said:
Are you assuming that the hot air is still the same temperature at the top, when the bucket turns over to let the exhaust air escape? Which would mean that you are creating power without extracting any heat energy. Yes, thanks for the right thinking on the project ... Alone in the beginning, I described these balloons as the largest heat engine ... .. But you can not say that it is a heat engine, because it just does not lose heat, and gives energy .. This escaping heat can be reused by building a roof at the top that will collect it and bring it back to the bottom of the device for refilling. By creating good thermal insulation, the heat lost will be minimal, and only theoretically we will have to supplement the heat lost as a result of putting it into the atmosphere, and not as a result of its loss for the work. So it's not a classic heat engine, despite the fact that it uses heat .. Andrew |
#605
Well, I see that I need to do the mathematical calculations step by step ...
so we have a 14m x 20m x 10m = 2800m ^ 3 bucklet ... he gives STRING at these 80 degrees Celsius those 500 KG of strength ... in a line, ALL bucklets give a total thrust of 12 x 500 KG = 6000 KG . Now the pulling wheels have a diameter of 20 meters, i.e. a radius of 10 meters .. So we get a torque of 6000 x 10 m = 60,000 Kgm. The circulation time of 1 bouquet is 100 seconds on this road 500 meters. or 500 meters divided by the circumference of the wheel, i.e. PI x D, 3, 14 x 20 m = 62 m, i.e. 500m / 62m = 8 turns, to overcome this path ... So one turn, that is 100 seconds / 8 = 12, 4 seconds lasts, i.e. 60 / 12.4 = 4.83 RPM per minute, on the wheel shaft, The power we get with such parameters is 4, 63 rev / min x 60,000 kgm = 335 HP. But now we can build it in a shaft dug in the ground, every 1000 meters deep, which is not a problem, and still part above the ground .. And of course further permutations .. Andrew |
#606
What have you been drinking? I want to avoid it.
#607
So you certainly know that for 5 years I have been sick with Miastenia Gravis, which significantly slowed down my activities, even in the possibility of performing cool animations, etc. .. But it also sometimes prevents everyday life ... I take medicine four times a day,
Pyridostigmine, under the name Mestinon. This medicine was discovered in 1935 by Mary Broadfoot Walker and is described as the MIRACLE of St.Alfege's. https://www.jameslindlibrary.org/art...K7Z2BYLDCp4kWg https://en.wikipedia.org/wiki/Pyridostigmine Thanks to this MIRACLE, I can live quite normally, although up to 70% of people who had it died before this disease. This is a very rare disease, which even most doctors do not know, which causes muscle weakness, including breathing, which caused death. During this time I had dozens of cases that my breathing was not as it should be due to various events, for example, a cold or prosaic forgetting to take the Mestinon drug, which works only 5 hours. Then when I was lying in bed I could not breathe ... But I practiced that you had to get up and sit in a comfortable chair, with the head back in quite a significant way it makes my breathing easier because I don't have to overcome the weight of my chest ... I was supposed to wait this period of 60 minutes before Mestinon starts working, because it absorbs and starts working only after those 60 minutes .. Then I could lie down in bed and fall asleep peacefully ... So I practiced dozens of times if I have difficulty breathing , I have to sit in a comfortable chair with a good head support, which makes breathing easier, even if I don't have a respirator ... I even fell asleep in it a few times and sleep almost all night. That's why I think how people they have breathing problems, for example because of the Covid-19 coronavirus, it would also be easier for them to breathe in such a sitting position in an armchair or deckchair ... and then they would not have to count on the assistance of a respirator .. Of course, oxygen can be given tube . also, in this sedentary position. Well, I think they would not require a supportive respirator that could be for the more severely ill. https://furnilux.pl/lezak-fotel-ogrodowy-laki My thoughts and advice therefore give me that, among other things, for the treatment of coronavirus also tried the medicine Tocilizumab, which is also effective The city of Gravis .. Well, I think that the use of a regular mask in already sick people is unnecessary, because it makes it difficult to get rid of the virus from inside the body, and it is known that the severity of the infection is determined by the amount of bacteria, so if nothing will hinder leaving the body, the disease may be milder .. Similar to vaccination - a small amount of germs does not cause the disease, but only makes it resistant to it .. Therefore, retaining germs with a mask in sick people is highly inappropriate .. Once on the forum I received from someone such a nice cap with the words Super Genius ".... now I modified it and added two spotlights with LEDs UV-C, or a similar UV.C lamp with a power of 7 watts, which will actively kill viruses 2 x 2 m in front of us .. It's good that it has a visor, because UV is harmful to the eyes .. But we can only use it when there is a high probability of infection, not all the time .. Anyway, active in the alcove with the virus, you can use an old street lamp, in which you should gently break the outer bulb, and the filament itself will be left, which sends a lot of disinfecting UV light ... But also great attention to the eyes ... But, for example, hands can be in it "Drip". I also think that patients could be put into the Solarium for five minutes , four times a day, then they would come home well tanned and with more vitamin D, which would increase their immunity ... Greetings to everyone and I fight with my myasthenia, because for now it is incurable ... But what I have already experienced thanks to it, describes it, because it may be useful to others ... Maybe some MIRACLE will come again ?? Andrew :chłodny: |
#608
Take care of yourself Andrew.
#609
Have you thought about re-designing the ventilator so that it could be easily manufactured, perhaps even DIY made at home?[/quote]
Thank you for your concern .. Vertilizer is a difficult thing, you can not do it at home .. But such a manual UV_C yes, to kill viruses can be done at home. I used to have to illuminate printed circuits made by myself .. Also, a face mask can have a secondary hose attached to such a system with a UV-C LED for water transfer in the aquarium .. if you add such a toy to the mask tube, it will show the air we breathe or exhale .. the power supply can be from a Power-Pack 10000 mah. The toy has a power of 0.5 watts, so for a few hours is enough .. and we only need about 1 liter of air every 8 seconds, so it seems that the performance would be sufficient .. The most important thing is that you are sick if you don't force anyone to wear a regular mask, because if we prevent leaving our body with viruses in a natural way, we can even bear the flu with ordinary flu ... You can see in the film how many drops in viruses leave we don't stop it by anything .. When we have a facial mask, most viruses stay in our mouths and our immune system will not be able to cope with it so much that he can recover quickly ... So my advice is how sick you are you can't wear a normal mask, but only turn away from people when you sneeze, so as not to infect them ... Well, maybe this mask with my UV-C diode can also help ... http://new4stroke.com/images/sneeze.mp4 Regards Andrew |
#610
Some detail more.. https://www.bbc.com/future/article/2...gSwdbHQRpag8do
Well, when it comes to fans, I also have this way: Because not all patients need this sophisticated equipment like a ventilator, I propose to use in lighter cases oxygen, but from such relatively cheap medical oxygen concentrators. they are cheap, it's probably easy and fast, they can be manufactured and at least partially replace respirators, which also require very specialized service. Such a concentrator, every person caring for a sick person will be able to properly handle ... https://www.ebay.co.uk/sch/i.html?_f...rator&_sacat=0 Andrew |
