Stripped the inside of alternator shaft - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Stripped the inside of alternator shaft
Old 11-08-2018, 05:11 PM
Scotty911 Scotty911 is offline
Scotty911
Default Stripped the inside of alternator shaft
Saw something about welding a cut off hex key in there - any other ideas? One day I’m going to need to remove the nut. Or break a fan belt on the highway.. thanks.
Old 11-11-2018, 08:48 AM
sithot sithot is offline
sithot
https://www.pelicanparts.com/techart...lternator2.htm
http://forums.pelicanparts.com/porsc...druff-key.html
Removing the alternator isn't hard but does take time.
Old 11-12-2018, 12:11 PM
cupomeat cupomeat is offline
cupomeat
Default Alternative
In the interim, you could get a strap wrench around the pulley. I did the same thing when I first got my 993 in 2007. Thought it was a hex...
Good luck!
