Plugged Tire at DE? - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Plugged Tire at DE?
Old 03-09-2018, 09:30 AM
Dandelion's Avatar
Dandelion
I think it would be helpful, Aaron, if you introduced yourself - from searching, I see you are the PCA National Treasurer - but with only 4 posts here, and none which describe your background and experience, most casual readers will have no context in which to assess your advice.
As you know, it's sometimes hard to match the name to the face at a DE.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 03-09-2018, 01:27 PM
I blew a tire at about 145 mph a couple years ago. Not really that big a deal. I wouldn’t sweat it.
https://youtu.be/BFWRTDqR3Ws
Old 03-09-2018, 03:18 PM
You've gotta admit - you look awfully calm in that video!!
IndexFingerRacing.com
Vicegrip: "The best way to buy speed in bikes is purchase less food. "
2009 911 C2S Coupe "The Green Car"
2004 Toyota Prius - Back-up DD
2016 Toyota Highlander (wife's DD and my new tow vehicle
2006 Dodge Durango - sold to a Dorki
2003 Acura MDX - Just shy of 200K
86 Black 911 Coupe race car (owned 2010-2016)
86 Gold 911 Targa (owned 1998-2012)
82 WineRedMetallic 911 Targa (owned 1986-7)
Old 03-09-2018, 04:35 PM
I like my version better
2011 Cayman S (Track Car) - Hardtop Blechster
Old 03-09-2018, 07:48 PM
A: Don’t you always.
B: Post it Boy-0
Old 03-13-2018, 08:11 AM
Aaron Ambrosino Aaron Ambrosino is offline
Aaron Ambrosino
Ed, I would be happy to introduce myself. Thanks to the power of Google you are correct that I am PCA's National Treasurer. As part of that duty I over see the National DE Committee. I will be celebrating my 28th year in PCA this May and have been involved in DE form the beginning. I am a second generation PCA member so I got my start DE'ing thanks to my father who was also my instructor. I have been instructing for 15+ years and completed the PCA National Instructor Training program in 2004.
Old 03-13-2018, 08:21 AM
Aaron Ambrosino
Do you know of any tire failures due to a plug?
Tires fail on track from time to time. We take that risk as a given knowing before we go ontrack that there is a known chance that a tire can fail. Do you replace any tires that were tracked at higher or lower than proper pressure? Those and other things like improper camber, overloading and overheating are known paths to reduced carcass life. It is the failure of the carcass that causes the high drama on track events.
Vicegrip, I cannot point to an instance where a plug failed on track. My point is why take a chance by plugging a tire that you know has been damaged. The safer bet is to replace the tire or depending on wear replace both.
With regards to your other hypothetical questions, if damage to the tire is evedent due to one of those issues then yes the tire should be replaced. Sometimes the damage is not easily visable and that is when bad things can happen. When in doubt replace the tire(s), in the long run it will be the cheaper option.
Old 03-13-2018, 09:23 AM
Vicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threads
And this is my point. Perception of risk driving recommendation rather than actual calculations. All the years of DE involvement, armed with no known evidence of a plug related carcass failure, the recommendation is still “replace” with the nod to “think of those around you too”. Often times and far more so with the heavy high HP cars damage or wear is not visible and best calculated out via usage profiles. Things we see or "feel" tend to be given far greater weight than risks we should be tracking but don't.
Way too easy to say “$100 head get a $100 helmet” or “best change it” while it is harder to find the root of and manage the real risks.
http://vimeo.com/29896988203100watts
Keepers of the cog. Rule#5#10#43
Until you multiply yourself times the speed of light squared. Then you Energy.
Science, Please.
Old 03-14-2018, 12:31 PM
Aaron Ambrosino
One issue with plugging or patching a tire is the quality of work done on the repair. The RMA has issued a Puncture Repair Procure for properly repairing tires.
http://www.rma.org/wp-content/upload...lchart1111.pdf
According to Michelin for a tire to maintain its warranty and speed rating it needs to be repaired by an authorized dealer to the RMA standards.
"For a repair to be considered acceptable the puncture must be smaller than 1/4 inch in diameter and repaired with the combination of a patch and a plug. The puncture must be far enough away from the sidewall and shoulder area to place a patch inside the tire without coming in contact with the sidewall and shoulder area. There is a maximum of 3 repairs per tire or 1 repair permitted for a run flat tire. Each repair location must be a minimum of 90 degrees apart. If these steps can't be followed then the repair is not acceptable and the tire must be removed from service. A speed rated tire will retain its speed rating as long as the tire is repaired to RMA standards."
For some brand of tires the speed rating may be reduced due to the repair.
https://www.tirerack.com/tires/tiret...jsp?techid=225
Lastly we do not know what damage could have been done to the tire if it was driven on below the recommend tire pressure due to the puncture.
Old 03-14-2018, 12:46 PM
#polishforprez
Is this a PCA De requirement?
- 2019 quickly disappearing...
