Strange PPI Results - Dorkiphus.net
Old 01-17-2019, 09:16 AM
N Fotouhi's Avatar
N Fotouhi
Default Strange PPI Results
This is on 2004 GT3 with 45K miles and 0 range 2 Over revs which would indicate missed shift. It is 2 owner car, and owned by the current owner since 2008 (about 17K miles), and has been primarily a track car, and in a very desirable condition with fresh suspension, and many services up to date. I am not willing to walk away from the car yet, but the fact that one entire side seems to show "something" is very strange.
All cylinders have very minor scoring.
Compression test: Cyl. 1 = 151 , 2 = 150 , 3 = 150, 4 =
145 , 5 = 145 , 6 =146 .
Leakdown test: Cyl. 1 = 4% , 2 = 5% , 3 = 5% , 4 = 19%
, 5 = 20% , 6 = 19%.
Check cam shaft deviation via tester. Bank 1 at -1.3.
Bank 2 at -3.73.
Additional usual checks to check for leaking valves and rings have shown no evidence of leak from either side.
I have asked for hot leak down and waiting to hear.
Any thoughts, ideas, or speculations?
Nader
Nader
There are 3 sides to every story. Mine, yours, and the truth.
91 944 S2 - Mine, Sold
7? 914-6 Vintage racer - Mine
93 964 - Not mine
95 993 - Hers - Sold and will be missed
04 GT3 - ours? Doing double duties at DE, anyway
06 987 - Hers - plan to let son use for DE - My DIY
A few others
Old 01-17-2019, 10:09 AM
Roo's Avatar
Roo Roo is offline
Roo
Well, if the rings and valves aren't leaking, the No 2 Bank cylinder numbers would suggest a head gasket leak.
Has an oil analysis and coolant analysis been performed?
Bank 2 at -3.73.
Nader
CT
83 911SC
12 Lexus CT 200h
08 Outback wagon
04 F250 SD
Truth be it known, I just like working on cars - Slick Henderson
Old 01-17-2019, 10:35 AM
What does this mean? When the leaks were detected there was nothing detected from intake or exhaust?
Seems to make sense, I'd want to check fluids.
Old 01-17-2019, 12:27 PM
A leak down shows more than a %. You can often tell where the air is going. Did they indicate where?
Old 01-17-2019, 01:35 PM
N Fotouhi's Avatar
N Fotouhi
The hot leakdown shows no difference.
After some checking and discussion, the hypothesis is that the differences may be an indication of differences in manufacturing tolerances between the two sides since there seems to be no mechanical indication.
I am also told by a reputable source that it is not unusual to see such differences in varioram engines.
If I buy and it blows up, I made the wrong call. Otherwise, it was nothing to worry about.
Nader
93 964 - Not mine
A few others
Old 01-17-2019, 04:45 PM
Thats a lot of leakdown deviation. Where was the air coming out? You can typically hear: Intake/case/exhaust.
Are they really on the compression stroke doing the 4/5/6 bank? (shop error?)
Old 01-17-2019, 05:19 PM
Old 01-17-2019, 08:00 PM
N Fotouhi's Avatar
N Fotouhi
Does compression stroke mean TDC?
I have no reason to think that the shop made an error since everything was rechecked over 3 days. There was no indication of leak from intake/case/exhaust. That is why the results are puzzling, and I have finally decided it may not indicate an issue.
Nader
93 964 - Not mine
A few others
Old 01-17-2019, 08:20 PM
Same procedure different day same result = no issue.
Old 01-17-2019, 10:02 PM
The air has to be going somewhere if it's leaving he cylinder. Did they listen? Where is the car located - perhaps a different shop... Mezger engine is supposed to be a tank--should tolerate a rebuild well but make sure the car is priced to allow for that (or mitigate the risk).
1999 Miata ("SM") race car
