Mostly over-heating of both the pads (melting) and fluid. People do get by as mentioned but bleeding them after ever session or every day. In my case I must of melted the fronts. I think the e46 spec series requires their use but those cars are maybe 500 lbs lighter and 120hp less.
Updated pic showing the brake line connections and fittings.
Proper ducting helps too, I run the Hard motorsport kit on my SE46.
www.hardmotorsports.com
95 993 16 GTI 02 BMW Spec E46 #27 01 Boxster 86 944- AER/Chump #33 20 F250 Tremor |
Paddy
Yup - that is the only reason I let the dust shields on. That and I did not want to take the bearings out and apart. |
