981 Replacement Brake Lines
Has anybody replaced their hard brake lines at the 981 caliper with stainless braided lines? I've heard several companies make kits which don't require you to removed the brake line bracket, but the only brand I've found is Spiegler which is quite pricy ($400).
Peter (not "Pete") K. 2016 Cayman S 1999 Miata ("SM") race car 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa |
I didn’t replace the hard lines but I did replace the fussy 10 mm bolt that holds the bracket with a small stud from Tarett. Makes manipulating the calipers much easier.
Same here. Haven't seen a need to switch out the lines to SS and with the stud it only takes a few seconds to remove the nut and pull up the bracket. Money on brakes will be better spent on the GT3/4 MC & Booster.
Mike 14 981 Cayman S Wall of Dearly Departed Loved Ones 07 987 Cayman S 03 996 86 944 74 914 78 924 Bro Code Rule 43: When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in. |
Thanks Jim and Mike. When I ordered the caliper studs I meant to order the bracket studs, too but the seem to have fallen out of my cart. Now the shipping is almost as much as the studs but I'm considering just buying some stainless threaded rod and using that.
Mike, how much of a difference did the GT3/4 MC make? I found my one weekend on the track that I had PLENTY of brake (using Ferodo 1.11 pads, stock rotors) and no fade in 25 minute sessions. I had to be careful coming into to SP turn 1 not to activate the anti-lock.
Much firmer brake pedal with greater ability to modulate the brake pressure. I used to constantly get into ABS and now it doesn't happen unless I want it to. The MC gives you a more robust unit and the booster has less boost pressure which firms up the pedal.
For the stud, it may be easier to find a longer bolt and just cut the head off. Mount with a dab of blue Loctite.
Indeed! The other benefit is that since the brake petal has much less travel, heel-toe is easier since the angle across the pedals doesn't vary as greatly.
John V 2024 BMW G87 ///M2 (Next 444) 2021 Toyota Supra GR (The Bupra, Other 444) 2016 BMW M235 2015 Porsche Cayenne Diesel 2007 Cayman S, #444 2013 Golf R 2012 BWM x5 2017 Mazda MX-5 Club 3 time DE Parade Lap Champion #BestInstructorEver - Unknown |
