987.1 Wiring Diagram
I found a blown 15A fuse in the rear fuse block but dont know what its for. Similar for the 2 other empty slots. Also, what are the relays for?
I'm working on a no brake light issue. PSM light is also on. Replaced brake light switch and bulbs and contacts are good. Thanks!
Found a diagram
Fuse 1 is for the engine compartment cleaner fan 2&3 are unused the relays are for AC and air pump IF the diagram is right
IIRC, there was only one fuse back there on my old '06 Cayman S.
2016 GT4 warp 7 1999 SPB warp 2, maybe 1973 914 2.0 1/2 impulse if it ever gets out of space dock Previous: 1973 914 1.7 1/4 impulse 2012 Cayman R warp 4 2006 Cayman S warp 3 1999 SPB warp 2, maybe 1966 911 warp 1.5 |
