#191
Only driving I'd be doing is driving it to the truck that's picking it up for it's new millionaire owner.
#192
More on the engine.
The cam housings are cleaned a bit. I had to drill out one of the exhaust studs. All the heads are cleaned and bead blasted. Looking at the crank case, it almost looks like there are inserts for the head studs. On the right is one of pistons from this engine. I cannot tell who made it, no marks on it. The piston on the left is a Mahle piston. Short after I got the car I found a set of piston and cylinders. I measured the set of piston and cylinders and they are out of the specs. The spare set I have is good. The cylinders from the engine are cast iron, the spare, right in the picture is aluminum. Here is a picture of the cylinder wall. I checked the run-out of the crank shaft and it was less than 0.01 Still sorting thru all the parts and see what need to be done. Cheers Engelbert
LED Lights for Classic Porsches 2012 Boxster S 2006 Cayenne S 1984 911 Targa, 3.4L 1982 911 SC 1978 1303 Kaefer Cabrio 1971 911 3.6 1966 912 - Future Project |
#193
Getting back on it.
Started sorting out some items and blasted the Cylinder cooling sheets. And powder coated them. One is missing in the picture. That need some small area repaired. Small stuff, but there will be more progress coming up soon. Happy New Year Engelbert
#194
Thanks for the update, the tinwork turned out really well.
#195
Are you sending the case out to get line-bored and all the rest? My '70T case needed quite a bit of help at the machine shop. BTW the advice I got was that if you switch to aluminum p/c's, you should install squirters in the case. The alum p/c's have closer tolerances than the iron/aluminum ones and temps need to be kept better in check or else you get premature wear.
#196
The Case Main bores need aligned ($$), the case already has squirters, will be hot tanked, media tumbled, cleaned, etc. The cams need to re-grind, new bushings for rockers, rods. New valve guides, valves, springs. I hope it will not add more to the list. I'm still have not decided if I go with Carrera tensioner, or keep it original. Thanks for the input. Cheers Engelbert
#197
As for tensioners, I went through the same considerations. The pressure fed tensioners are crazy expensive now so what I did is get my idler arms rebushed with wide bushings (Henry at Supertec does this for about $140) and used SC tensioners that I rebuilt myself. You should be able to get core tensioners for $100 and the rebuild kits for $40/pair. The wide bushings plus rebuilt SC tensioners is pretty much bulletproof, saves a ton of money, and looks stock. |
#198
I think I will end up the same way with my case, Oh boy. Cheers Engelbert
#199
Here's a pic from my tensioner rebuild. It's actually pretty simple -- some threads on Pelican cover it.
#200
Thanks Engelbert
