Does this look like alignment or bearing problem - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Does this look like alignment or bearing problem
Old 11-01-2023, 06:16 AM
Thrust angle.
Old 11-08-2023, 09:03 AM
dnwong's Avatar
dnwong dnwong is offline
dnwong
So, I went to have new tires mounted and the tech said that was due to worn struts. I did not take the car there so he was only commenting based on how the tire looked. With the larger M5 sway bar, it is hard to do a accurate bounce test but still seems pretty tight.
They don't look blown and passed inspection. So, you think he is mistaken?
Dudley
Aldie, VA
99 996 C4 Black/Black Areo
86 951 Graphite / Burgundy
2002 BMW 530i
2008 Volvo XC90
1995 Chev Astro (workhorse going-bald)
My Garage Build
Old 11-09-2023, 07:25 PM
Have you had the alignment checked by a competent tech with accurate, calibrated equipment? Anything less is a guess.
Yes there are some simple easy to diagnose issues but modern multi link suspensions often require a trained examination to diagnose.
Old 11-11-2023, 05:28 AM
dnwong's Avatar
dnwong
Yes, my next step is to get an alignment. I figure if I needed rear struts, I would do them first before getting alignment and not have to do it twice. Car has been a garage queen for many years now.
Dudley
Aldie, VA
2002 BMW 530i
2008 Volvo XC90
My Garage Build
Old 04-05-2024, 08:31 PM
PorschePriest PorschePriest is offline
PorschePriest
Originally Posted by dnwong View Post
Here is the passenger side.
Quick guess ? - Alignment problem
