My Wife's 1978 VW 1303 Restoration - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » My Wife's 1978 VW 1303 Restoration
Old 01-10-2014, 02:35 PM
Congrats on the Hall of Fame! Well deserved
Like we didn't see that coming....
Old 01-11-2014, 08:14 PM
rothaus's Avatar
rothaus rothaus is offline
What type of coating, yellow zink ?
I found some hardware yellow plated with the correct grade (10.9) at bellmetrics
Anyway, please let me know what type of coating.
Thanks
Engelbert
Originally Posted by antonioconceicao View Post
Very good sir! If you need a place for plating parts the shop I am using at Ohio does a great job.
Nice!
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
Old 01-11-2014, 08:59 PM
antonioconceicao's Avatar
antonioconceicao
They also do the yellow zink.
http://www.aetnaplating.com/
Not sure about the grade call them and talk with owner
Antonio
Thanks
Engelbert
2007 997 Turbo
1990 G Wagon Diesel
1990 Porsche 964 C2 G
1985 Citroen CX GTI
1988 Citroen BX GTI
1976 Vespa GTR 125cc
1970 Citroen Mehari
1968 Citroen ID 20
1965 356 C
.... There are some things on this car - like the rear suspension - that are very familiar to us old 911 guys.
and the shots of the front (suspension and boot) look like prequels for the 964 and beyond.
Old 01-11-2014, 09:46 PM
rothaus's Avatar
David, you have seen the Beetle a little over a year ago.
Quite honestly I would rather work on the 911, however, you got to make sure the other (better) half is OK.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 01-11-2014, 10:44 PM
Cheers
Engelbert
and I remember it well! As others have said I had no idea it had so much that needed to be done! With the engine mods it looks like a fun car to run around in too.
Old 01-13-2014, 10:07 PM
rothaus's Avatar
So, now I moved to the left side.
A bit crunchy here
Once the outside skin is gone, it looks not that good any more
More crunchy stuff.. outch
Need to make some cuts
One piece is gone.
It is getting thin
Looks like a few pieces to fabricate...
At this point I decided to replace the complete reinforcement rail on the left side, since I repaired that piece (I'm shocked) 15 years ago. This way I will have a nice strong base.
OK, enough of this, I will move to something more fun. Re-assembly of the chassis:
Preparing some brake lines
And installing them, as well the master and rear cylinders
The rest of the brakes, etc. is for next weekend.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 01-14-2014, 08:52 PM
I need more popcorn! Thanks for posting all the picks. That Bug is going to be brand new!
Old 01-14-2014, 09:18 PM
slbates's Avatar
slbates slbates is offline
slbates
Nice work!
I had a 69 beetle. The floor pan was full of holes...had to use a propane torch to thaw the pedal cluster in the winter on a regular basis. It quit running once when the battery fell through the floor and shorted out. I would says yours is a relatively rust free example in comparison
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 01-21-2014, 10:20 PM
rothaus's Avatar
More progress:
Installing the brake shoes
and drums
Ok... now we are moving to the right rear corner
It didn't look that bad, however, as more you dig in....
And before you know it the hole get's bigger
Trying to find the good material to weld on to.
Fabricating some new pieces
And weld them in. No comments needed
Finishing up the outside
To be continued
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
