broken head stud removal? - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » broken head stud removal?
Old 09-04-2014, 09:34 AM
rothaus's Avatar
rothaus rothaus is offline
Here is how I did it with not much left to hold on.
http://dorkiphus.net/porsche/showpos...3&postcount=10
Cheers
Engelbert
2012 Boxster S
2006 Cayenne S
1984 911 Targa, 3.4L
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
1966 912 - Future Project
Old 09-04-2014, 10:32 AM
Casey914's Avatar
Casey914 Casey914 is offline
Casey914 has two HoF threadsCasey914 has two HoF threads
Originally Posted by catron1 View Post
This stud extractor could work for you, "German Made" its a little pricy but worth it. $139
http://www.samstagsales.com/klann.htm#web_special
Search titan stud remover on amazon... looks to be the same one for $30.
Old 09-04-2014, 01:30 PM
crg crg is offline
crg
had it welded and removed, took all of 5 minutes...good advice, thanks!
craig
1989 C4
Old 09-04-2014, 01:41 PM
Another happy ending!
I'm just curious if the braintrust thinks that the welding approach also provides some of the needed heat into the broken bolt/stud, facilitating its eventual removal.
Old 09-04-2014, 01:55 PM
crg crg is offline
crg
I'm no braintrust nor do I play one on tv but it def did heat it up enough to melt that loctite
craig
1989 C4
Old 09-17-2014, 07:55 PM
Bird watcher Bird watcher is offline
1986 911 Carrera
Bird watcher
That tool worked for me to remove my broken head studs, I wonder how he got through the exhaust bolts..
Old 09-18-2014, 12:51 PM
Fairfax 944's Avatar
Fairfax 944 Fairfax 944 is offline
Fairfax 944 has one HoF thread
When I welded a nut onto a broken motormount stud on an aluminum Audi engine, the stud turned out quite easily. Prior to the welding, I tried two different stud removers and applied extreme pressure (and also heat from an acetylene torch), but had no luck.
The heat from the welding definitely had a big effect on my job.
Jim
1986 Porsche 944 Turbo
Old 06-23-2019, 05:59 AM
mikedsilva mikedsilva is offline
mikedsilva
hi gents, I'm new to this forum..
I'm trying to remove some broken dilavar studs from a 3.2... According to the Pelican How To, they say you cannot weld a nut to dilavar...
But above, you have done it.
I just bought myself a 3 in 1 welder.. Mig, Stick and Lift Tig.
Can I ask what type of weld you used? And what sort of wire or filler rod you used?
Dilavar being an alloy, can a steel nut be welded to it?
Thanks for the help
