Perhaps a noobie question, but that 20% is a pressure difference measured before the cylinder and after correct? That sounds like a big drop indicating air is going somewhere, but I am not expert.
Is a number like that in of itself indicative of a mechanical problem? A few things come to mind off the top of my head that could allow air to escape such as a bad seal in ring, valve, head gasket, or even a crack in the block/piston/head. The most common/simple would be what, rings or valves? Or nothing? Should there be other indicators like excess pressure in the cooling and/or oiling system if the air isn't escaping to the outside?
Rafi Z. 2002 C4S (FOR SALE) 1987 944 (Coil Overs, sold) 2000 Boxster (Long Gone) |
#12
Never been accused of being smart, I made an offer that stuck.
Hoping for the best, and will handle the worst, if happens. Likely will put it on dyno to decide if further examination is warranted.
Nader There are 3 sides to every story. Mine, yours, and the truth. 91 944 S2 - Mine, Sold 7? 914-6 Vintage racer - Mine 93 964 - Not mine 95 993 - Hers - Sold and will be missed 04 GT3 - ours? Doing double duties at DE, anyway 06 987 - Hers - plan to let son use for DE - My DIY A few others |
#13
That's cool, and the right attitude.
A rebuild is rarely much over $40k these days. So you will be spending less on this car than on your last one
#14
Awesome! No fear. No paranoia.
#15
Fixed that for you Congratulations on your new whip, pictures or it didn’t happen.
#16
The only difference between my garage and Ryan's is that every time I buy a Porsche, I have to stop and pick up a jar of Vaseline on the way home.
#17
You buying Porsche OE Vaseline or that cheap Yugoslavaline?
#18
