Need help please
Hello all,
I bought the Bilt racing 2 qt sump extension for my 986 and would love to do the installation myself. All I'm lacking is a garage with a lift (minor issue ). Do you know of a place I could rent a lift for a day? It's supposed to be a ~3 hr job, but then there is cure time for the sealant before oil goes back in. I have the quickjack and could do it that way, but I'd rather be able to have more room than that gives me. Thanks for your thoughts, advice! |
A lift is nice, but really isn't necessary. I have done multiple deep sump installations, without any lift.
You just need to get the car up on jackstands high enough that you can comfortably work underneath it. And, you need to make sure the car is level on the jackstands. For work like this, I prefer to use wheel cribs -- they don't interfere with using jacks on the jack points, and the car will be level once it's up on the cribs. You can make your own out of lumber, or you can get some like these: https://www.raceramps.com/c/cribs/
2016 GT4 warp 7 1999 SPB warp 2, maybe 1973 914 2.0 1/2 impulse if it ever gets out of space dock Previous: 1973 914 1.7 1/4 impulse 2012 Cayman R warp 4 2006 Cayman S warp 3 1999 SPB warp 2, maybe 1966 911 warp 1.5 |
Do you have a picture or two of them in use with your many project cars
Karl Lucky owner of a couple of 911’s and another Porsche |
If you're going to make your own out of lumber, go as high as you feel comfortable jacking up your car. Just make sure they are strong. Plenty of pics in the interwebs. Either way, you'll need a good jack (or a pair of jacks) to get the car up. The nice thing about the RR 14" version is you can lift one side up halfway, then the other side all the way up and then go back and raise the other side the rest of the way. Don't have any pics, but they wouldn't be very exciting anyway -- just a car up on blocks.
The OP has a Quicjack which should give him 24” at the second lock point. That is higher than you can get with Jack stand or the fancy stuff Bill uses. Quick Jack should give plenty f lift for putting on the deep sump.
Sounds like he wants to do this standing up under the car.
Nader There are 3 sides to every story. Mine, yours, and the truth. 91 944 S2 - Mine, Sold 7? 914-6 Vintage racer - Mine 93 964 - Not mine 95 993 - Hers - Sold and will be missed 04 GT3 - ours? Doing double duties at DE, anyway 06 987 - Hers - plan to let son use for DE - My DIY A few others |
Had to check that out, nice cinderblock I've made similar from plywood, 2x10s, whatever was on hand. Nice solution though.
Large blocks of structural foam and a floor jack are fancy?
If so, then you'll love my trick for sliding under cars -- large sheets of cardboard cut from big shipping boxes! They maximize room under the car, insulate you from the cold floor and can be rolled up and thrown away when they get dirty or oily. Oh yeah, there are plenty of options. However, you should never use cinderblocks, they are known to crack and crumble without warning.
Thanks for the advice Bill and the additional comments.
I would prefer to stand, but honestly, as I go over the job in my head (and youtube), the only 'under the car bit' is removing and replacing the sump pan - everything else will be done at the bench. Mostly, I am weary of the mess when the pan comes off given the residual oil that will be there while I'm on my back...but that can be dealt with. Thanks again for the advice! Niel V Last edited by Molly2001; 02-27-2023 at 08:50 AM. |
You'll learn to reach over your head while lying on your back to keep from being drenched in oil. You still have the risk of getting splashed if standing. Get a large, low-profile plastic tub/tote to catch the mess when you separate the sump plate.
As others have said, the Quick Jack will give you plenty of room if you're comfortable working on your back. An air or electric impact will reduce the amount of over-the-head reach time for removing the screws. Oh, and for those who use concrete/cinder blocks as supports, they need to be oriented such that the casting holes are vertical, not horizontal.
Jerome Welte '97 Spec Boxster '20 Nissan Titan XD |
"large sheets of cardboard cut from big shipping boxes"
Good, but big political candidate signs are infinitely more durable as they are corrugated plastic and readily available once an election is over. Not absorbent however. I have a lift the OP is welcome to use for a day but I live up near BWI airport.
1986.5 928 |
