What is the name for this clip? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » What is the name for this clip?
Old 05-10-2021, 03:02 PM
Mark Hubley's Avatar
Mark Hubley Mark Hubley is offline
Mark Hubley
Default What is the name for this clip?
What is the name for this type of clip? I am missing a couple from the front end of my 951, where the "bat wing" attaches.
2015 Cayman GTS
2021 Jetta R-line
2016 F-250
Formerly owned Porsche/BMW:
1986 944 Turbo
2006 325i
2000 911
1987 924S
1999 Boxster
1986 944
Old 05-10-2021, 03:07 PM
KFJ's Avatar
KFJ KFJ is offline
Lemming
KFJ has one HoF thread
J-Clip and U nut are terms I've heard and seem to work with the google.
Kirk J.
78 911 SC euro spec
05 Audi S4
01 Audi A6 - gone...
Things are made of stuff -Bill Nye
Old 05-10-2021, 03:40 PM
u style spring nut or speed nut
Old 05-10-2021, 07:34 PM
racer's Avatar
racer racer is offline
racer
Lolz. My dad use to call them Jesus clips.. cause when they'd spring off you'd say "Jesus, where'd that go!"
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 05-11-2021, 05:05 AM
A couple of versions of U nuts. Fixed and floating. Porsche used mostly floating. The nut is square and trapped in a box on the U clip. This lets the nut adjust a bit when the bolt is being inserted. It also lets the little nut retainer rust then break under under stress leaving the nut to spin around while you try and remove the bolt.
U clips are like a U nut but rather than formed threads there is a punched and formed hole in the spring steel. They are intended for screws.
Old 05-11-2021, 07:50 PM
Tim P Tim P is offline
Tim P
944online.com has diagrams identifying the parts and locations. very helpful.
Tim
04 Boxster
88 944S
87 944 Turbo
Old 05-12-2021, 03:39 PM
jerome951
The parts Mark is asking about are U clips. No captured nut.
Mark, I may have a few laying around if you're in a dire situation. If not most of the well-known parts suppliers carry them.
Buy extras....
Jerome Welte
'97 Spec Boxster
'20 Nissan Titan XD
Old 05-12-2021, 03:46 PM
Funny
I didnt know there was a thing called a circlip coming up, jesus clip was a good catchall for just about anything you knew could fly across the shop at a moments notice.
Old 05-12-2021, 04:09 PM
Mark Hubley
Thanks all for the info. I had come across an official parts diagram of the front end that did not show these particular fasteners. Now I have found one that does. They are cheap enough that I ordered a stash. Figured that might be easier than trying at Autozone. At least I have proper words for them now!
2015 Cayman GTS
2021 Jetta R-line
2016 F-250
1986 944 Turbo
2006 325i
2000 911
1987 924S
1999 Boxster
1986 944
