Wheel bearing removal tool, help - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Wheel bearing removal tool, help
Old 02-02-2022, 10:28 PM
turkis_tii's Avatar
turkis_tii turkis_tii is offline
turkis_tii
Default Wheel bearing removal tool, help
Planning to replace the rear wheel bearings on my 996, hopefully off the car. Looking for anyone who can loan me the Sirtools B90-3J or equivalent and other accessories for this job.
- John
‘00 Porsche 996 C2
'72 BMW 2002tii
'92 SCCA SSM (sold)
'80 SCCA SRF3 (sold)
'89 Porsche 944 (sold)
'59 Porsche 1600S (long gone)
Old 02-03-2022, 07:29 PM
I've got it and am local. I'll PM contact info,
1999 Miata ("SM") race car
Old 02-04-2022, 08:46 AM
And it comes with a Curry's Discount Coupon!
Now Craftsman Auto! Matt started up another chain.
Old 02-04-2022, 07:17 PM
My Apologies, that was inappropriate. Thanks for helping a fellow Dorki, Dr. K!
Old 02-04-2022, 09:20 PM
slbates's Avatar
slbates slbates is offline
slbates
The bearing can be changed on the car. I was able to change the wheel bearing on my 996 C2 many years ago using a the B90 kit and a tutorial from a boxster racing forum (they accomplished this trackside). It was surprisingly easy to do and was one of the few times Murphy didn't pay me a visit. I did but the new bearing in the freezer overnight before installing.
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 02-05-2022, 06:52 AM
Chilling the bearing does not hurt but Heating the socket the bearing goes into has a far greater effect. A bearing will slide into a well warmed aluminum carrier without any force. The socket should also be cleaned and burnished of any nicks and burrs.
I have started to CAREFULLY open and inspect the amount of factory installed grease in every sealed bearing I use regardless of brand. I and others are finding many name brand and replacement brand with little to no grease.
Old 02-05-2022, 08:27 PM
turkis_tii's Avatar
turkis_tii
The front bearings came out with difficulty (corrosion) and the “grease” had solidified to wax, could not identify manufacturer. Hopefully the NTNs will last.
- John
‘00 Porsche 996 C2
'72 BMW 2002tii
'92 SCCA SSM (sold)
Old 02-05-2022, 09:26 PM
I've tried freezing the bearing and under Kurt's direction heating the socket. There is no comparison--heating the socket to "gut-and-hot" and using a pole in the bearing to slide it in straight is very much better.
Old 02-11-2022, 07:08 PM
slbates's Avatar
slbates
Kurt, I forgot to mention that I heated the hub with a HF heat gun. I was uncomfortable using a torch on the carrier.
I didn't even think to check the bearing to see how much grease was in there. That's good advice. Do you remove the factory grease and replace it with a different kind or is it ok to mix n match? If I ever have to do this again I will be sure to check the fill.
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 02-11-2022, 09:28 PM
I have both a torch and a HF heat gun - I can't imagine the heat gun getting the carrier hot enough for the bearing to just slide in, and sliding in is safer and easier than using the Sir Tools tool (which I also have). Did you get the carrier hot enough with the heat gun for the bearing to just slide in without any force?
