CV joint grease - Page 2 - Dorkiphus.net
Old 01-03-2022, 11:54 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Keep in mind the grease does no good if it is just in the boot and not in the the ball bearings and cage. On our track cars, removing the entire axle and hand packing the CV's is a yearly maintenance procedure. Over the years I have found that the CV that is closest to the muffler/exhaust is the one that the grease gets dry first and is most likely to fail. For cars that get tracked, it is a good idea to install a vent tube (a piece of a red spray straw from a brake cleaner works well) on the axle side of the CV boot. Oetiker clamps are the best since you can make them as tight or loose as you want and are easy to install if you have the axle off and CV and boot removed. Good high quality zip ties (the ones with the metal tooth) work well if you don't take everything apart.
Some ideas here
https://1c2a8a2161d644d95009-22d26b3...TDR4628CVJ.pdf
Steve Potomac PCA Co-CI
89 944 Turbo Racecar, used to win a bunch of races
98 993 C2S w/Aerokit II
77 911S project
70 Boss 302
86 Mustang SVO
08 F250 SD Diesel
15 Audi SQ5
Old 01-05-2022, 09:07 AM
onboost's Avatar
onboost onboost is offline
onboost
A MY 2013 car should not have dry CV issues. I have to wonder about that.
YMMV.
My first thought as well..
RGruppe #180
PCA Potomac + 35yrs
Old 01-06-2022, 02:27 PM
Molly2001 Molly2001 is offline
Molly2001
Some ideas here
Great info - I'll add this to my winter routine. Thanks
Old 01-07-2022, 04:54 PM
mlytle mlytle is offline
mlytle
If anyone is interested, I have two unopened 120g packets of GKN CV joint grease. Free to someone who can use them.
https://hosting.photobucket.com/imag...107_154812.jpg
Marshall
75 M2
88 M3
97 M3
Old 01-14-2022, 10:44 PM
turkis_tii's Avatar
turkis_tii turkis_tii is offline
turkis_tii
Yeah, I was going to ask about whether there’s an issue mixing different brands or types of grease.
- John
‘00 Porsche 996 C2
'72 BMW 2002tii
'92 SCCA SSM (sold)
'80 SCCA SRF3 (sold)
'89 Porsche 944
'59 Porsche 1600S
Old 01-15-2022, 10:23 AM
Yes. You can run into problems mixing different formulations.
Old 01-19-2022, 04:14 PM
Molly2001
Has anyone here used the Rein CV Boots from Pelican?
They sell a kit with Genuine Porsche Boot clamps, Circlips, Swepco 101P-986-0401-A, and Rein CV Boots. Are the Rein Boots any good? I'd be using them for an annual CV grease service since I track the Boxster.
Thanks
