#271
Martin, I can't remember, but did you have a hardtop for the boxster? If so I'd be interest in buying it for Lori's car. Also, you inbox is full
Thanks, Paddy
95 993 16 GTI 02 BMW Spec E46 #27 01 Boxster 86 944- AER/Chump #33 20 F250 Tremor |
#272
OK, I'll delete my fan mail....
Sorry, no hardtop. Too aerodynamic for the Blechster. Check with @BobNovas
#273
Put on the brakes for the left front so the front is done. Finished the right rear so I could lower the car - found that the steel female cone where the toe arm connects to the carrier was missing. So I needed to break the nut on the axle to replace the left rear carrier. Assembled the left rear but not torqued yet. Cleaned the transmission and the new carrier.
Hopefully the car will be on the ground tomorrow.
#274
Woo hoo
Sent from my iPhone using Tapatalk Pro
#275
Left rear torqued. Lowered on to ramps (thanks Ion) to torque LCAs, diagonals and Diamond plate on and torqued. Suspension finished. Everything is new except the shocks and thrust arms. New LCAs, Toe Arms, Tie Rods, Drop Links, Rotors, Pads.
Some messy projects left. Deep Sump, CSF radiators, Motorsport Electric Power Steering. A few sensors to remove (brake pressure, engine oil pressure). Under drive pulley. Going to leave on the CAI and filter as I don't think I can get the old air box in without dropping the engine.
#276
Martin, are you going to sell the deep sump? If so I'm interested, thanks.
#277
Deep sump removed. OE back on. Brrrrrrrr
#278
The End. Off to a good home and someone that can finish the conversion after the power steering drug on too long. Needed it gone and now it is. I will list the go fast parts for sale after I clean them up.
