Ouch (said my rear hub) - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Ouch (said my rear hub)
Old 08-02-2011, 11:29 PM
Default Ouch (said my rear hub)
I assume this is secondary to the backed-off axle nut on my driver's side rear wheel, but could it have been causative? Ben noticed the hub was loose (really loose) with the axle out, so I took the caliper off tonight - and (most of) the hub fell right off (with the rotor). I caught it (yes, I was as shocked as you all are). Here are some photos.
Hopefully somebody has one (Fritz--email sent) and I already have a new bearing. Might want some help this weekend with this. I have a huge list of things to do to get the Dawe engine ready for install--this was the last thing I needed, but I might take half a day off work Monday if I don't get enough done over the weekend.
Name:  Broken hub close-up.jpg
Name:  Trailing arm and e-brake with broken hub1.jpg
1999 Miata ("SM") race car
Old 08-02-2011, 11:53 PM
Wow... that's a new one on me. Explains the backed off axle nut.
Old 08-03-2011, 07:28 AM
WOW. Really good you caught this.
As for pure speculation: 1) When the axle nut is really tight, that should put the whole stub statically in compression. Not sure if road forces are enough to overcome that w/o doing some math. But I guess how I can see *if* the nut had backed off on its own, then *maybe* something like this could happen due to cyclic fatigue. Or 2) more simply, it always had a defect in the casting/forging and was just doomed to fail eventually.
Old 08-03-2011, 07:39 AM
My money's on the nut came loose first, allowing the movement which causes the subsequent wear/damage on the hub itself.
Old 08-03-2011, 07:44 AM
Good note for everyone, when your car feels wonky, pit in and check it out until you find something. I had a similar situation a few years ago, hack shop left some trailing arm adjustment bolts loose after an alignment. Scary stuff.
Old 08-03-2011, 08:32 AM
Agree but only a guess on my part.
I have seen a few stubs break in the same location. Get a new/replacement stub and assemble 100% per book. The bearing could be left in place and reused if you pull the hub stub out in the right direction while backing the bearing on the inner race. I might be inclined not to and install a new one.
Can't stress this enough. It looks like this car was driven in this condition for some time. bad hub or loose front wheel bearing can give a long brake pedal along with or without noise. If it feels wrong or something has changed come in and find out why.
Old 08-03-2011, 08:43 AM
This is the kind of stuff that starts happening when you are just too fast for the car you are driving. Dr. K maybe your skills are now beyond this car.
http://agent.allstate.com/SBresnahan/Welcome
2005 Cayenne
Old 08-03-2011, 09:02 AM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
Like to hear from Matt on this. My guess is the nut was not properly torqued. Or the car was hit hard at one point in its life causing a crack to start, or maybe a pot hole. Good find.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 08-03-2011, 09:27 AM
Fritz's Avatar
Fritz Fritz is offline
Addict
Fritz has one HoF thread
Email returned. I can get it to you shortly.
Old 08-03-2011, 10:16 AM
We've had similar breaks .. but mainly due to wheel to wheel or wheel to door or wheel to "X' contact. More often the trailing arm will bend / break (cast aluminum) versus the hub.
Glad you found it. I'd check the other side as well, just for Ha Ha(s).
