#21
Dirk
#22
Add a third bay should be fairly reasonable cost wise. I have been toying with the idea of adding a 3rd bay to my 2-car side load garage. Especially if you don't take down the existing exterior wall that would become a interior wall.
Since your house is all brick, there are probably other challenges to doing that. In my case, I would remove the siding, the water table and replace with drywall.
#23
Nothing a lvl and a sledgehammer cant fix
I'm glad I removed the wall between my new and old space, frees up a ton of space for access or just filling it with more stuff
#24
Oh, I forgot to mention, I wanted to use it for a woodshop. Need dust control anyways...lol
#25
When adding the third bay I recommend opening up the original exterior, now interior, wall as much as possible. This will give you room to open doors without a wall in the way, and generally makes for a much nicer space. I did this when adding my third bay and had an engineer help with the design. In the second picture the white horizontal section that spans the top of the newly opened wall contains an LVL beam that transfers all the added roof weight down to the slab footings.
#26
Punch a hole through the tree line at the top of the driveway and we have plenty of room. See below, this picture is behind the tree line and the fence at the top of the driveway. Plenty of room for a second free standing garage but... I’m certain that “she” would want to add a pool house etc. on top of a new garage We are now into project creep... Most of the older homes in the hood, like mine are tear downs, so a major project is ill advised.
Karl Lucky owner of a couple of 911’s and another Porsche or two Last edited by Patrick3000; 05-04-2021 at 10:27 AM. |
#27
Kiss.
Build one more car storage bay next to existing 2 car garage. Do not touch existing garage exterior wall. Offset front and rear 6" to foot so don't have to splice walls. Use same pitch on roof and new roof will tuck under existing roof. This design will save $ because no f'ing with existing garage. Use lvl ridge beam and 2x12 rafters to get cathedral ceiling. Install lift if need store a 4th car.
Clarke 68 912 75 911S Gemini Blue 3.0L 10 GT3 18 S6 22 F250 King Ranch Gone: 18 F250 King Ranch 12 F450 Lariat 11 GT3RS silver 11 GT3RS white 10 Cayenne GTS 08 Cayenne S 06 997 C4S cab (2) 05 997S C2 Launch 04 M3 Laguna Seca Blue 02 996 cab 91 964 C4 82 911 SC Euro 3.0 (3) 78 911 - 3.2 77 911 75 911S 73.5 911T 73 911T 72 911T 71 911T RSR vintage racer 3.0 69 911T Kermit vintage racer 2.0 68 911 Maximum Freedom, Minimum Government http://www.lp.org/ |
#28
This is the massing relationship I'm describing with offsets and lower roof
#29
#30
Yes. Two heavy posts at the ends of the LVL transferring the load to the slab footing.
