What is the name for this clip?
What is the name for this type of clip? I am missing a couple from the front end of my 951, where the "bat wing" attaches.
2015 Cayman GTS 2021 Jetta R-line 2016 F-250 Formerly owned Porsche/BMW: 1986 944 Turbo 2006 325i 2000 911 1987 924S 1999 Boxster 1986 944 |
J-Clip and U nut are terms I've heard and seem to work with the google.
Kirk J. 78 911 SC euro spec 05 Audi S4 01 Audi A6 - gone... Things are made of stuff -Bill Nye |
u style spring nut or speed nut
Lolz. My dad use to call them Jesus clips.. cause when they'd spring off you'd say "Jesus, where'd that go!"
A couple of versions of U nuts. Fixed and floating. Porsche used mostly floating. The nut is square and trapped in a box on the U clip. This lets the nut adjust a bit when the bolt is being inserted. It also lets the little nut retainer rust then break under under stress leaving the nut to spin around while you try and remove the bolt.
U clips are like a U nut but rather than formed threads there is a punched and formed hole in the spring steel. They are intended for screws.
944online.com has diagrams identifying the parts and locations. very helpful.
Tim 04 Boxster 88 944S 87 944 Turbo |
Mark, I may have a few laying around if you're in a dire situation. If not most of the well-known parts suppliers carry them. Buy extras....
Jerome Welte '97 Spec Boxster '20 Nissan Titan XD |
I didnt know there was a thing called a circlip coming up, jesus clip was a good catchall for just about anything you knew could fly across the shop at a moments notice.
Thanks all for the info. I had come across an official parts diagram of the front end that did not show these particular fasteners. Now I have found one that does. They are cheap enough that I ordered a stash. Figured that might be easier than trying at Autozone. At least I have proper words for them now!
