I need a weld - Dorkiphus.net
Old 06-17-2021, 05:24 PM
cmcfaul@aol.com cmcfaul@aol.com is offline
need for speed
cmcfaul@aol.com
Default I need a weld
The rear engine carrier (thing the engine mounts to in the rear) is cracked on one mount. Can anyone weld it for me? Can be sloppy just needs to be strong.
Cash or beer
Thanks,
Chris
89 Carrera
73 911 E
89 Carrera
Old 06-17-2021, 06:02 PM
Cash or beer
Thanks,
Chris
89 Carrera
Feel like taking a drive? I know just the cracks and how to not just fix but prevent more in the future. The downside is I am 90 min from the beltway
Old 06-17-2021, 06:52 PM
need for speed
cmcfaul@aol.com
Thanks.
Appreciate the offer. Guess you moved. It's a bit too far round trip.
Chris
73 911 E
89 Carrera
Old 06-17-2021, 06:56 PM
Yup I moved. No worries, plenty of folks can hot glue metal.
Old 06-17-2021, 11:13 PM
hot glue, love it!
Not hard to do an ok job, especially if you rattle can it
Old 06-18-2021, 11:42 AM
edevinney's Avatar
Most Courteous Driver
edevinney
I have a very hot glue gun and barely adequate skills but am up the road in Purcellville and will be around this weekend if you want a quick amateur job.
Purcellville
993 + Boxster S + Eurovan MV + 4Runner + Volvo 122
Old 06-18-2021, 11:54 AM
FWIW, the trip to VG's new stronghold is worth the trip. The entire property is very cool. Think of it like visiting the King of the Mountain.
- 2000 Boxster S (the wife's)
- 1979 RX7 enduro
- 1986 944 (under new mgmt)
Old 06-18-2021, 12:54 PM
need for speed
cmcfaul@aol.com
Another question for the collective.
I replaced the clutch (g50). The pedal goes almost to the floor before engaging the clutch (shift fork moves about 3/4 inch before pedal hits the floor). Does it need bleed or adjusted?
thanks
73 911 E
89 Carrera
Old 06-18-2021, 01:34 PM
Chopper Dropper's Avatar
Chopper Dropper
thanks
Don't believe there is any mechanical adjustment on the G 50 clutch!
1988 911 Targa
1986 944
Old 06-18-2021, 04:22 PM
Double check the pedal, is the pin worn out? Did you open the hydraulic system? If so bleed again.
