Plugged Tire at DE? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Plugged Tire at DE?
Old 03-04-2018, 08:51 AM
RestonGuy RestonGuy is offline
RestonGuy
Default Plugged Tire at DE?
I found a screw in my left rear Michelin PS4 tire on my C2S.
I will probably replace it anyway for safety, but would a properly plugged tire (plugged from the inside) be acceptable for DE?
John S,
2010 911 C2S (daily driver #1)
2009 Audi S5 (daily driver #2)
1979 Audi 4000 (gone)
1972 914-2 (gone)
1977 924 (gone)
And Others…..
Old 03-04-2018, 09:12 AM
#polishforprez
Typically yes. (assumes a street tire, and less then Red Group speeds)
- 2019 quickly disappearing...
Old 03-04-2018, 10:17 AM
trytryagain's Avatar
trytryagain
And location of plug well away from the sidewalls?
Jim C.
1986 911 Targa (Aka "Dusty")
1971 914 (back in the day)
Old 03-04-2018, 06:49 PM
Agree and this is Paul's view, too (Radial Tire Paul). So long as the plug is in the tread and properly applied, it's good for DE or race.
IndexFingerRacing.com
Vicegrip: "The best way to buy speed in bikes is purchase less food. "
2009 911 C2S Coupe "The Green Car"
2004 Toyota Prius - Back-up DD
2016 Toyota Highlander (wife's DD and my new tow vehicle
2006 Dodge Durango - sold to a Dorki
2003 Acura MDX - Just shy of 200K
86 Black 911 Coupe race car (owned 2010-2016)
86 Gold 911 Targa (owned 1998-2012)
82 WineRedMetallic 911 Targa (owned 1986-7)
Old 03-05-2018, 07:21 PM
RestonGuy
Thanks guys.
The screw is in a treadblock, not the sidewall. May just go ahead and replace it, but keep the plugged tire for later use.
John S,
1972 914-2 (gone)
1977 924 (gone)
And Others…..
Old 03-07-2018, 08:11 AM
Aaron Ambrosino Aaron Ambrosino is offline
Aaron Ambrosino
Originally Posted by RestonGuy View Post
Thanks guys.
RestonGuy good decision to replace the tire. I know others say a plug will be fine, but is it worth taking that chance on track. Tires take a lot of abuse on track compared to the street. Since tires are what connect you to the driving surface it would be wise to not run a damaged / repaired tire. If the plug or tire fails not only do you risk damage and or injury to you and your car, but others on the track with you.
Aaron
Old 03-07-2018, 09:13 AM
Chopper Dropper's Avatar
Chopper Dropper
Paul at Radial tyre is a very experienced racer and performance tyre guru, I would not be concerned at all if he personally did the plugging. He has done that for me in the past.
Dirk
Co DE Chair, PCA Potomac Region.
1988 911 Targa
1986 944
Old 03-07-2018, 12:33 PM
RestonGuy
Default Tire Repaired
Today I drove up to Radial Tire (where I purchased the tires initially).
Paul inspected the tire and personally installed a plug. It is some sort of super plastic plug. He uses it for street and racing tire repairs.
He said I should have no concerns taking it on the track.
I'll drive on it over the next few weeks to see how it does.
John S,
1972 914-2 (gone)
1977 924 (gone)
And Others…..
Old 03-08-2018, 10:11 PM
Dirk
Now that I've gone to the Dark Side, I've had a chance to watch Paul win his class in quite a few races! Good idea to listen to Paul instead of some guy only Vu knows... (well, he is Treasurer of PCA, and apparently an approved PCA tech site - welcome to the board, New Yorker).
Old 03-09-2018, 07:23 AM
Vicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threadsVicegrip has six HoF threads
Aaron
Do you know of any tire failures due to a plug?
Tires fail on track from time to time. We take that risk as a given knowing before we go ontrack that there is a known chance that a tire can fail. Do you replace any tires that were tracked at higher or lower than proper pressure? Those and other things like improper camber, overloading and overheating are known paths to reduced carcass life. It is the failure of the carcass that causes the high drama on track events.
