you know what makes our hobby look cheap? - Page 48 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » you know what makes our hobby look cheap?
Old 05-24-2020, 08:39 PM
edevinney's Avatar
Most Courteous Driver
edevinney
The heat sink came with the board. I picked the Meanwell switching supply because It had a good reputation for low/no RFI and there didn't seem to be any reason not to use a switcher. The $30 price was a boon, too. It also seems to be the right power supply for the preamp upgrade coming next.
Purcellville
993 + Boxster S + Eurovan MV + 4Runner + Volvo 122
Old 05-26-2020, 12:43 PM
Charlie Stylianos's Avatar
Very cool! I just ordered a case to enclose the TPA3251EVM-175W board and meanwell PS I bought a year or so ago. Will be the amp for the bedroom setup.
The Korg tube is pretty neat. Will add some tubey flavor as a preamp. Looking forward to impressions.
Kyriakos E. Stylianos
Baglama inspired
Old 05-26-2020, 01:15 PM
Please share when you get it going, I dont understand what makes it work but the results are just too cool.
Old 05-26-2020, 06:24 PM
edevinney's Avatar
edevinney
That's some else's pic, still waiting on parts from a group buy but I'll definitely report back.
I have a couple of regular Pass B1 boards and enjoy them, am hoping the Korg can help with the slight shoutiness of some female vocals that comes through the chipamp. Aretha deserves Respect.
Purcellville
Old 07-09-2020, 02:03 PM
edevinney's Avatar
edevinney
So far, so good: board populated, no smoke on startup, voltages stable at the test points and bias set to Mr Pass's baseline. Sounds very good, have to spend some time listening carefully later.
Purcellville
Old 07-09-2020, 09:26 PM
Nice, Ed. I need to do a build. I picked up a pair of free, mint ADS L620s a few weeks back. They don’t need a lot of power.
Old 07-09-2020, 11:46 PM
edevinney's Avatar
edevinney
Oh, you should - this has been fun, not terribly expensive, and definitely rewarding.
Having listened to this combination for a couple of hours now, I'd recommend the preamp. Adds a nice bit of ambience and soundstage vs the B1 buffer, with the same lovely detail. Aretha and Sister Rosetta Tharpe seem to like it, too. The only down side is that the tube is microphonic, so it turns outside sound into electrical sound. You really need to put the preamp in a sturdy, closed case to keep out vibration or it rings like a bell.
More than you'll ever want to know here: https://www.diyaudio.com/forums/pass...rg-triode.html
Spent the evening spec'ing out a case and front panel, which will be the largest single cost of the whole thing. Rough total (I reused some parts like the volume pot) about $625:
$70 3e TPA3251 board
$30 Power supply
$30 preamp board and JFETs
$50 Korg NuTube
$75 other preamp parts
$100 front panel w/machining
$180 case
Purcellville
Old 07-11-2020, 10:59 PM
Croc R's Avatar
Croc R Croc R is offline
Croc R
Default FM Tuner recommendations
My inexpensive but good sounding tuner has apparently died. I am looking for recommendations for a replacement.
Harleigh
(ex-'60 356B Roadster, '70 914-6, '85 911, '94 968, 2012 Cayman R)
Old 07-12-2020, 08:56 AM
Price range?
Old 07-12-2020, 12:28 PM
Croc R's Avatar
Croc R
Price range?
Definitely under $1K, preferably under $300.
Harleigh
