FS: 1976 Porsche 912E, Minerva Blue w/ Cashmere Beige Leather - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Porsche & BMW Cars For Sale/Wanted » FS: 1976 Porsche 912E, Minerva Blue w/ Cashmere Beige Leather
Porsche & BMW Cars For Sale/Wanted Post For Sale or WTB adds for Porsche & BMW cars here. Strictly moderated.
Old 07-02-2019, 09:31 PM
IanLarsen71 IanLarsen71 is offline
IanLarsen71
Default FS: 1976 Porsche 912E, Minerva Blue w/ Cashmere Beige Leather
Hi, all.
I just moved back inside the Beltway after three years in the Shenandoah Valley. I no longer have a garage, so I need to let go of my '76 912E. If you're not familiar, the 912E was a one-year-only model introduced in the U.S. market to fill the gap between the end of the 914 run and the beginning of the 924. It's the 911 body with the same 2 liter type 4 engine as the later 914 cars. It runs L-Jet fuel injection. Only 2099 were built.
The photo sharing feature on these boards can be wonky, so I'm posting pictures on Google Drive instead: https://drive.google.com/drive/u/0/f...CMmvBYrao_kgAX
This is an exceptional example of the 912E. It has factory sunroof, power windows, and AC. (I have removed the AC compressor, but it's included in the sale.) It also has H1 headlights, which are a step above the H4 lights. H1 lights frequently sell online for $1200.00-$1500.00.
I believe I am the fourth owner. The first owner is unknown. The second owner was in Charlottesville, Virginia. He bought the car sometime in the 80s and held it for roughly 30 years. The third owner was a collector who purchased it in 2017 to restore. I bought the car from the third owner in 2018 after he decided to focus on a 72 911 instead. He did a bare metal respray in Minerva blue in 2017 and he began installing a new cashmere beige leather interior. I finished everything else.
Very nearly everything has been done on this car, and it has not been driven since the the restoration began. I've pasted at the bottom of this post a list of everything that has been done to the car since the restoration began in 2017. As you'll see, it's pretty extensive. It would be difficult to find a better overall example of a 912E for sale anywhere.
The only weakness the car has is that it has the typical rust in the battery tray area. (Not sure why the PO didn't deal with this when he ad the car painted.) The rust will need to be corrected eventually, but it's not urgent. That fix is $500-$700 in parts, plus 30-40 hours of labor. You could also replace the original front clip with a good used one $200-$300 plus labor.
Hagerty values 912E cars with sunroofs as follows:
Concours: $53,550
Excellent:$39,795
Good:$26,250
Fair:$15,750
The battery tray rust is the only thing keeping this car out of the excellent category for valuation purposes. It is otherwise exceptional.
I'm looking for $35,000, with some room for negotiation.
As of this writing, July 2, the car is still with my mechanic in Waynesboro. It will be delivered to my NOVA mechanic on July 8.
Happy to answer any questions you may have.
Ian
WORK COMPLETE, 2017-2019
Body
Bare Metal Respray – color change from Sahara Beige to Minerva Blue Metallic *
Replaced front valance #
Replaced front bumper impact strip #
Replaced wiper fluid reservoir #
New wiper fluid reservoir filler hose #
New wiper fluid filler hose cap #
New front bumper baffles *
New plastic trim/piping between front fender and front wheel well panel #
New front trunk hood seal *#
Replaced front Porsche badge #
New front fender piping #
New windshield wiper arms and blades #
New windshield wiper mount gaskets, bolts, and caps #
New rocker panel covers *
New rocker panel rubber trim *
New rocker panel end caps #
New front windshield gasket and metal trim *
New rear window gasket and metal trim *
New sunroof gaskets and trim #
Sunroof tracks cleaned and lubricated #
New decklid ventilation grill T-bolts #
New rear bumper impact strip *
Installed Euro rear bumper buffers/bumperettes *
New rear bumper baffles *
New trim/piping between body and rear wheel well panels *
New exterior door handle gaskets *
Interior
New lower door sill covers and trim *
New door window exterior trim *
New door weather stripping #
New quarter window gaskets *
New MOMO Prototipo steering wheel *
New MOMO horn button *
New shifter boot #
New handbrake boot #
New black German vinyl headliner *
New A pillar trim *
New B pillar trim *
New seatbelt boot *
Replaced front seatbelts #
New Interior dome lights #
New black sliverknit carpet *#
New rear wheel housing panel sound absorbers, left and right *
New rear panel/package shelf insulation *
New leather front and rear seat upholstery – cashmere beige *#
New leather door cards – cashmere beige *#
New leather rear/quarter window cards – cashmere beige *#
Reupholstered upper door garnish in leather – cashmere beige #
Reupholstered door pockets in leather – cashmere beige *#
Reupholstered quarter window garnish in leather – cashmere beige #
New rear package shelf cover – black vinyl *
New door vapor barriers #
New rear view mirror #
New sun visors #
New brake and clutch pedal covers #
New accelerator pedal #
New shifter bushings, front and rear #
New passenger side footrest#
Fuel System
New fuel tank *
Replaced fuel expansion tank behind driver’s headlight #
New expansion tank hoses #
New fuel level sender, gasket, and protective bracket #
New fuel tank/fuel filler joiner hose #
New fuel tank upper hoses #
Replaced fuel filler pipe and cap #
New fuel pump #
New fuel filter #
Wheels/Brakes/Drive Shaft
Rebuilt brake calipers #
New brake pads #
New brake master cylinder (purchased, not yet installed) #
Replaced brake fluid #
New brake fluid reservoir drain tube #
New rubber brake lines *
New rear metal brake lines #
New Tires *
New inner CV joint boots (purchased, installed passenger side only) #
Electrical
Replaced front running lights #
New battery in 2017 *
Installed and aimed Porsche H1 headlights *
New headlight gaskets *
New fresh air fan motor #
Converted from manual to power windows *#
Door window motors and mechanisms lubricated #
New power window wiring harness #
New passenger door window switch wiring #
New power window relay and relay wiring #
New turn signal switch #
New door window switches #
Rebuilt rear lights #
New rear license plate light bulbs #
New LED lights for dash instruments #
New wiper fluid pump #
Confirmed alternator function & cleaned contacts #
Engine/Engine Bay
New charcoal canister hoses #
New mass airflow sensor #
New temperature sensor II #
New spark plugs #
New spark plug wires #
New fuel injectors #
New fuel injector seals #
New vacuum hoses #
New dual fuel pump/fuel injection relay #
New voltage regulator #
Replaced oil breather #
New oil breather gasket #
New fuel pressure regulator #
New Pertronix ignition coil #
New Pertronix Ignitor II #
New distributor cap #
New air filter #
New fan belt #
New intake manifold gaskets #
New intake manifold connecting hoses #
New air intake boot #
New muffler *
New oil pressure sensor #
Oil change #
New oil filter #
Cleaned oil strainer #
New oil strainer gasket #
New engine bay insulation #
New decklid shock #
New decklid bumpers #
New decklid seal *
New rear relay panel cover #
Adjusted valves #
Adjusted timing #
New valve cover gaskets #
Repaired heat exchangers #
Performed compression test (see results below) #
Performed fuel pressure test (see results below) #
Tested function of all fuel injection components except ECU (see results below) #
* Denotes work done solely by third owner in 2017/2018
# Denotes work done solely by current owner in 2018/2019
*# Denotes work started by third owner and completed or corrected by current owner in 2018/2019
PARTS STILL NEEDED
Tire jack
Door pocket covers and hinges
Rear valance and gasket
Rubber trim between body and rear bumper
Rear seatbelt hole plugs
Front trunk carpet and bulkhead cover
Front fuse cover
Headlight relay
Test Results
Compression Test – Compression is Good
Cold engine at 1500 ft. elevation 3/10/19:
Cylinder 1 – 135 0.96 = 140.625 at sea level
Cylinder 2 – 140 0.96 = 145.833 at sea level
Cylinder 3 – 135 0.96 = 140.625 at sea level
Cylinder 4 – 135 0.96 = 140.625 at sea level
Fuel Pressure Test – Fuel Pressure at idle is Good
Fuel pressure measures 35 psi at fuel rail. Measurement taken with ignition on, engine off, fuel pressure regulator vacuum hose removed, and AFM door held open with screwdriver. Measures ~29 psi at idle with vacuum hose attached.
Aux Air Regulator Test – Aux Air Reg is Good
Test ohms on aux air regulator. Should be 30 ohms when engine is cold. – checked 3/25. Measures exactly 30 ohms. Visually inspect aux air regulator when engine is cold and off. Should be open. – checked 2/22. Aperture is open with engine cold. Apply 12 v to aux air regulator. This should slowly close the opening. – Tested 3/25. Applied 9 volts rather than 12, and regulator did close slowly. Regulator is OK.
Cold Start Valve Test – Valve is Good
Test cold start valve by removing it, place it in a bag, and start engine while it’s cold. Should provide fuel for a max of 20 seconds. – Tested 2/25. It provided fuel for several seconds. Perhaps 30-45 ML worth. Check ohms on cold start valve. Should be about 4 ohms. – checked 3/25 after removing it from the car. Measured exactly 4 ohms. Valve is OK.
Thermo Time Switch Test – Switch is Good
Test ohms on thermo time switch when engine is cold. Should read 25-40 ohms if temperature is below 86 degrees Fahrenheit. (per 912e Service Information document). – Tested 3/25. Reads 32-33 ohms. Switch is OK.
Throttle Valve Switch Test – Switch is Good
Take off cover. Contacts should not touch when idling. Should touch when revving. Contacts should measure zero ohms with throttle wide open. – checked 2/22. Contacts were not touching in idle position. Did touch when throttle moved to full open position. Measured zero ohms when throttle was open. Switch is OK.
Temp Sensor II Test -- Replaced
Check ohms on temp sensor ii. Should be 2-3k ohms at room temp. Around 5-6K if temperature is in the 30s-40s. This can be measured at the ECU plug by testing terminals 13 and 17. -- Function unknown. Replaced temp sensor ii 3/5/19
Fuel Pressure Regulator – Regulator is Good
Apply compressed air to inlet side. Without vacuum, it should be around 36 psi. It should be lower when vacuum is applied. – Tested 3/25. It measured 35-37 psi w/o vacuum and 27-28 psi with vacuum. Fuel pressure regulator is OK.
Double Relay – Relay is Good
Measure resistance at pins 85 & 86b. Should be between 50 and 100 ohms. Measures 61 ohms. Relay is good
Old 07-03-2019, 09:12 AM
I'll post some photos of the 914 2.0 in a tuxedo for ya...
Cool odd-ball cars!
'73 914 2.0 (2.7/6 conversion in progress)
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
Old 07-03-2019, 10:50 AM
IanLarsen71
Thanks for doing that!
Old 07-03-2019, 10:56 AM
No problem:
Do you still have the a/c parts on the engine, and the heater tubes (don't see them on the blower motor)?
'02 S6 Avant
'99.5 A4 2.8QT
'65 Falcon 80
Old 07-03-2019, 10:59 AM
IanLarsen71
Yes. It's all there. I have the original AC compressor as well as the hoses. I took the heater tubes off while I was working on the engine. They're reinstalled now.
This is the only decent engine bay pic I have at the moment, but I can post more when the car arrives in Falls Church on Monday.
I should point out that the rubber air intake tube has also been replaced with a new one since this picture was taken.
Old 07-09-2019, 06:01 PM
IanLarsen71
Update: car is now with my mechanic in Springfield. He'll do a few small things over the next few days. It should be ready for test drives early next week.
