Anyone using Toyo RR tires? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Anyone using Toyo RR tires?
Old 07-15-2019, 04:54 PM
Default Anyone using Toyo RR tires?
Man, we used to talk about track stuff in here more....anyhow ...
My RA-1 are about used up time for some new shooz. I tracked the number of days I got on my tires and it was double digits. Not heat cycles, DAYS.
They keep coming back for more punishment. But was looking and see that RR tires are between an RA-1 and a Hoosier. They are within a few bucks of RA-1s.
I'm so cheap that I don't want to spend Hoosier money though wouldn't mind the performance (or much of the performance)
Anyone here have experience with these? Performance, lifespan etc.
Thanks.
Old 07-15-2019, 09:15 PM
mlytle mlytle is offline
mlytle
Huge step down from Hoosiers, kook z214 or bfg's. Not even in the same league.
And to make it worse, they only last about 10 heat cycles before grip and predictability fall away.
I had used several sets of them and they are now on my permanent "do not buy again" list.
It is unfortunate that kook stopped making the z214s this year.
Marshall
95 M3
97 M3
Old 07-16-2019, 07:37 AM
Official tire of Spec Boxster. Maybe Streak will chime in. Definitely more grip than the RA1 but not as many heat cycles for sure.
http://agent.allstate.com/SBresnahan/Welcome
2005 Cayenne
Old 07-16-2019, 09:03 AM
N Fotouhi's Avatar
N Fotouhi
I remember and miss the trash talk. But, we were young and enthusiastic then, now, we are old(er) and ill tempered. Kind of like TR has always been
I have not used RR, but have listened to Hunt echo what was said above.
I have stopped buying Hoosier because I have no need to get ready for the "big" race, and also with 2 of us driving, that is a new set every weekend which is more fun than I want to have. Also, the faster I spend money, the slower I get these days, so my goal is to slow the rate of descent.
You driving the heck out of that S2. How about going to 18" wheels to get more tire under it? like 245/18 NT01 all the way around.
Nader
There are 3 sides to every story. Mine, yours, and the truth.
91 944 S2 - Mine, Sold
7? 914-6 Vintage racer - Mine
93 964 - Not mine
95 993 - Hers - Sold and will be missed
04 GT3 - ours? Doing double duties at DE, anyway
06 987 - Hers - plan to let son use for DE - My DIY
A few others
Old 07-16-2019, 09:27 AM
Le Cochon Volant's Avatar
Le Cochon Volant Le Cochon Volant is offline
Le Cochon Volant
Listen, listen, listen...
Sorry, couldn't help myself. Google "Trackdaytires" and see if Todd has any scrubs in your preferred sizes. $600 for a set of lightly used scrubs that will probably last you three events is a good value to me.
Edit: I should have said "gtracingtires". The other site is the hoho vendor. My mistake.
Holder
1969 911S
1999 996 C2 Coupe (The Flying Pig)
2016 GT3 Cup
2015 GT3
1988 951
1989 944 S2
2002 Boxster S (project)
1972 914 1.7
2013 Cayenne Diesel (wifey's DD)
2007 E350 4matic wagon DD
2008 Chevy 3500 dually tow truck
Old 07-16-2019, 09:52 AM
Good data points guys thanks.
Nadar thanks for noticing me out there!
Old 07-16-2019, 10:06 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
Spec tire for NASA Spec3. You can get about a race season out of them, when rotated correctly / diligently.
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 07-16-2019, 10:44 AM
PGas32 PGas32 is offline
PGas32
In my experience, the outright grip drops off after the first handful of heat cycles, but it's not a steep drop off and it remains steady and predictable for a long time after that. I've come within tenths of the track record at NJMP on RR's with over 20 HC's on them.
I've never driven on anything but RR's so my experience is limited, but it sure seems to me that longevity is one of the strong points.
1999 SPB v2
2001 911 track/race car
2016 Cayenne GTS
2021 Ford Explorer
Gone:
2006 Cayman S
2006 911 S
SPB v1
Old 07-16-2019, 11:03 AM
Paddy's Avatar
Paddy Paddy is offline
Paddy
Interesting thread. It's also the spec tire for SpecE46 and I have different results.
I agree they're not nearly as fast as a Hoosier or BFG, but they do seem to last a long time. For example, this past weekend at PittRace I started the weekend with a set with 21 heat cycles and was only .7th off my best time fro last year. They're also a little weird when new especially at VIR. I find them to be nearly a full second slower when new over a set scrubs with ~10 heat cycles.
As for lifespan, I won all 4 races this weekend vs racers w/ stickers. My tires that ended up with 27 heat cycles worked just fine and still have life in them. I turned my fastest lap on Sunday's morning race with 26 heat cycles.
I'll probably run them during the practice session this weekend at Summit.
16 GTI
02 BMW Spec E46 #27
01 Boxster
86 944- AER/Chump #33
20 F250 Tremor
Old 07-16-2019, 11:12 AM
Dandelion's Avatar
Dandelion
Thanks.
Hey Steve - aren't you going to the NASCAR race at the Glen? Maybe you can pick up some takeoffs.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
