#61
#62
green duct tape is in the works. if it peels, i'm not fixing.
it only looks bad until it gets cold out. |
#63
Kevin Oyler '88 944 Turbo S "Don't let a few facts get in the way of a good story" |
#66
Your statement will be true some, or even most, of the time, but it will not necessarily be true all of the time. Analyzing time segments is the only way to know. For example, in some constant radius turns, it might be possible that you can maintain such a higher speed through the outside of the turn (e.g., maybe due to the particular camber of the turn) at a lower g-force than you can through the inside of the turn at a higher g-force that you overcome the disadvantage of the additional distance you must travel. In other words, despite the longer distance traveled and the lower "perceived" g-force, you might have a higher exit speed than you did with the shorter distance traveled and the higher "perceived" g-force. In short, the line that "feels" faster may not actually be faster . . .
Thank Me Dammit! |
#68
I thought headaches were only relevant when trying to maximize access to g-spots, not g-sums
Thank Me Dammit! |
#69
that's b/c they keep swinging that purse and it keeps hitting the same spot on the back of the head
#70
More photos, less analysis.
