Miscellaneous Discussions Off Topic (OT) items that really don't fit into any other Category |
Any termite experts?
I was planning to refinish some wooden deck furniture from Restoration Hardware. When I turned over one of the chairs, I see what looks like mud trails on the bottom. However, I have a 2 story high composite deck. I always thought ground contact is necessary for termite to attack. And only the one chair out of 6 was affected.
What kinda of bugs do this kind of damage? So, I took the chair apart. Did not see any bugs in the eaten wood. To be safe, threw all the infested wood away and kept the good pieces for spare parts. Or should I throw the whole chair away to be safe?
Dudley Aldie, VA 99 996 C4 Black/Black Areo 86 951 Graphite / Burgundy 2002 BMW 530i 2008 Volvo XC90 1995 Chev Astro (workhorse going-bald) My Garage Build |
Are you referring to the holes? or are they screw holes? I've had carpenter bees leave similar holes. But it sounds like the holes should be there and its fungus. Cleanup with a borate solution.
Carpenter ants
Karl Lucky owner of a couple of 911’s and another Porsche or two |
Dudley noted no signs of insects. Carpenter ants only damage wood they intend to live in or pass through, they don't eat wood like termites do.
OTOH Dry rot fungus is often localized and some forms look just like his images. There are a number of them that fall under the "Dry rot" grouping. Random google found site with images. https://www.permagard.co.uk/advice/t...ry-rot-wet-rot Easy to deal with. Replace the bad wood. borax or weak chlorine soak and keep things under 20% moisture content.
Those are screw holes. But they were filled with the reddish brown stuff. I dug a couple of the holes to see what was in there.
Recommend NOT using search terms "Dudley's dry rot" or "Dudley's fungus"
So, you think this will work for my wood fungus...
