951 Fuel Lines
So I decided to take on a COVID project this weekend on the 951. I bought a set of Rennbay fuel lines back in 2015 and was going to attempt to change them out today.
I started to take the car apart and removed the return line that goes to the regulator. The new replacement line is really tight so before I cut the hard line, I wanted to take an assessment of the old lines to justify the effort. The old line look really clean the the rubber hose were still flexible. In fact the original hose look thicker than the new hoses. I need some opinions as to whether it really needs to be replaced. The car is really clean and even the tub under the liner has very little dirt. Seems like I may not gain much from changing out the lines. Any thoughts would be appreciated.
Dudley Aldie, VA 99 996 C4 Black/Black Areo 86 951 Graphite / Burgundy 2002 BMW 530i 2008 Volvo XC90 1995 Chev Astro (workhorse going-bald) My Garage Build Last edited by dnwong; 04-19-2020 at 04:39 PM. |
Replace it. The ethanol in the fuel now eats from the inside out so you can't go by the exterior. The newer hoses are a bit more tolerant to ethanol. A little trick I do is to flip the FPR 180 degrees so it feeds from the firewall side and allows you to route the new lines closer to the firewall. (See the pic)This helps so some of the radiant heat from the manifold doesn't convect straight up on the lines. You can also wrap them with any kind of header wrap or heat reflecting material for extra protection. Make sure to test fit with whatever length of hose you got. The compression fittings need to be staggered so they are not next to each other.
Steve Potomac PCA Co-CI(retired) 89 944 Turbo Race car 85.5 944 NA son's 2015/2019/2020 944Cup and PCA Nat'l Champ racecar 94 968 1 of 11 Iris blue coupes 92 968 1 of 2 Tahoe Blue Cabriolets 98 993 C2S w/Aerokit II 77 911S Vintage race car project 70 Boss 302 86 Mustang SVO 08 F250 SD Diesel 15 Audi SQ5 "Noel spun! Noel spun! Don't do anything stupid, Dad." -the boy on the radio on the last lap of NASA race as the second place car spins behind me in T5 at Summit Point. Last edited by TurboPooch; 04-20-2020 at 03:53 PM. |
