i need airbag light help asap! - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » i need airbag light help asap!
Old 11-06-2019, 03:54 PM
Originally Posted by Otto View Post
i am not sure this helps get past the va safety inspection process
they expect the light to come one when the engine is started, then go off once the system does its system test
It does but like dating high school gurls timing is everything! Just like the air bag seat belt Light will come back on quickly.
Best option I found was the jumper wire. Or possibly finding a sparky that can figure out a way to convince the system that the belts are being used or thereís no one sitting in the seat.
Old 11-07-2019, 01:03 PM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
Does WV have a state inspection? If not, You may consider garaging your car at Summit Point. State registration is determined by the principal garaging location not your residency.
Never mind, I looked it up and WV has a safety inspection...
Jim
White '91 SSM Miata #01
Yellow '19 718 Boxster (Wife's)
Black '15 GMC Yukon XL w/ '98 Trailex (Tow Vehicle)
Orange/Brown-ish '75 FJ40 (in case I run out of other car projects)
Old 11-07-2019, 02:21 PM
Otto's Avatar
Otto Otto is offline
Otto
Originally Posted by KONG View Post
Hey Otto - Can it be disabled with a PIWIS? If so, I might be able to help..
it would be great if we could try
Otto
#906
2014 Cayman S
2012 Cayman S - retired
2006 Boxster S
Old 11-07-2019, 04:52 PM
Fumes's Avatar
Fumes Fumes is offline
He HIT me.
Fumes
just put in the stock seats, get your sticker, swap them back, electrical tape
or call tpc talk to tom - he knows these things
2012 987.2 R (endless build)
2009 997.2 C2S
2012 F-150 (tow)
2013 991.1 C2 (sold)
2013 335i (RIP)
2001 4Runner (left by side of road in Georgia)
1990 Legend LS (RIP)
1988 Toyota 2WD reg cab (donated)
1987 GTi (sold)
1990 (TOM)Celica GTS (RIP)
Old 11-08-2019, 10:20 AM
Otto's Avatar
Otto
tried tom, it seems the 981 are difficult to configure
i have head that intersport and asg have the wherewithal to get it done, so i know it can be done
i really don't want to be swapping seats in and out each year
Otto
#906
2014 Cayman S
2006 Boxster S
Old 11-11-2019, 07:24 AM
Jabs1542's Avatar
Jabs1542 Jabs1542 is offline
Jabs1542
^^ This ^^ Itís how I do it in the 991.
The newer cars run on a digital bus network so wire jumping doesnít work anymore, and the passenger seat has a larger molex connector due to the weight sensor built into the seat (detects if passenger airbag needs to deploy or not).
Bus example: My center consoled has about 7 buttons on it, yet when you pull the button package out you see it is all wired with a thin 3-wire ribbon cable. It takes programming at the dealership to add a single button and enable it.
I miss analog
Jay
2013 C2S
Racecars are like strippers, we just keep throwing money at them hoping someday they give us the ride of our livesÖ
Jabs1542's Avatar
Jabs1542
Sometimes I miss analog
Jay
2013 C2S
Old 11-11-2019, 09:41 AM
jhsmith's Avatar
jhsmith
http://t-design9.com/ claims to make modules which spoof the digital buttons on modern Porsches. Likely doesn't fix the airbag light issue but you can always ask them.
Jim
Old 11-11-2019, 05:35 PM
Otto's Avatar
Otto
yes
i think the only way to do this is with a porsche piwis (sp?), if it is even possible
Otto
#906
2014 Cayman S
2006 Boxster S
Old 11-12-2019, 07:50 AM
Fumes's Avatar
He HIT me.
Fumes
as opposed to effing with the ECU every year? swapping seats is much easier buddy
and even if you do disable the light itself, you may still have a fault in the ECU since there is no airbag there -- which will be revealed in the OBDI scan -- and you'll fail inspection anyway since you are in a modern car and (for good reason) there's no good way to game the OBDI scan
2009 997.2 C2S
2012 F-150 (tow)
2013 335i (RIP)
1987 GTi (sold)
