i need airbag light help asap! - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » i need airbag light help asap!
Old 10-04-2019, 11:55 AM
Otto's Avatar
Otto Otto is offline
Otto
Default i need airbag light help asap!
after piper motorsport installed my omp track seats, i was surprised that lap belt buckles "worked", meaning the light and alarm went off when buckled
however, the PWS sensor and the seat mounted side airbag fault is still an issue
i need this issue solved so i can get my stupid va safety sticker
tysons porsche would not do it
who do we know that can, and is willing to, adjust the programming so the car knows it has seats without airbags and without passenger weight sensors?
thanks
otto
Otto
#906
2014 Cayman S
2012 Cayman S - retired
2006 Boxster S
Old 10-04-2019, 11:59 AM
Paddy's Avatar
Paddy Paddy is offline
Paddy
ASG or Intersport can do this for you.
16 GTI
02 BMW Spec E46 #27
01 Boxster
86 944- AER/Chump #33
08 F250 Diesel
Old 10-04-2019, 06:00 PM
Doc_S's Avatar
Doc_S Doc_S is offline
Doc_S
Otto,
On my 987 Boxster, I turned the warnings & lights off with a Durametric. I don’t know if that’s possible on a 981. But I have durametric pro if you want to give it a try.
Mark
Mark S
2005 Boxster S - G Stock #667
1978 Triumph Spitfire
06 Harley VROD
Old 10-04-2019, 06:52 PM
trytryagain's Avatar
trytryagain
I haven’t checked recently but last year it was not possible on a 981 with a Durametric. Also, I’m not sure whether ASG will do this service due to liability concerns. Intersport would be worth calling.
Jim C.
1986 911 Targa (Aka "Dusty")
1971 914 (back in the day)
Old 10-04-2019, 11:05 PM
Otto's Avatar
Otto
Originally Posted by Doc_S View Post
Otto,
Mark
i am not sure this helps get past the va safety inspection process
they expect the light to come one when the engine is started, then go off once the system does its system test
Otto
#906
2014 Cayman S
2006 Boxster S
Old 11-05-2019, 11:36 PM
KONG KONG is offline
KONG
Hey Otto - Can it be disabled with a PIWIS? If so, I might be able to help..
Old 11-06-2019, 01:19 AM
Check the inter webs for the DIY on running a jumper wire from one of the other lights.....
Old 11-06-2019, 10:25 AM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
Time for a Montana LLC
Jim
White '91 SSM Miata #01
Yellow '19 718 Boxster (Wife's)
Black '15 GMC Yukon XL w/ '98 Trailex (Tow Vehicle)
Orange/Brown-ish '75 FJ40 (in case I run out of other car projects)
Old 11-06-2019, 12:38 PM
Call me Scooter
Black electrical tape
http://agent.allstate.com/SBresnahan/Welcome
88 911 E stock
2005 Cayenne
Old 11-06-2019, 12:59 PM
#polishforprez
VA safety inspector might notice that.
- 2019 quickly disappearing...
