Need some heat in the garage..
Im looking for something safe and fiscally reasonable to heat my 3 car garage. Let me know what you guys are using.
Vincent 2009 E350 4Matic 1987 325is 2024 Integra 6spd 2021 CX-9 1998 M Roadster - Sold 2021 Taco - Sold 2009 E91 Touring - Sold 2005 S$ Avant - Sold 2007 Carerra S - Sold 1976 911S - Sold Acura MDX - Dead 2000 e39 528i/5 - Sold |
chili
Mr.Heater - 20000 BTU natural gas heater from Home Depot.
Al W. 2001 911 cab |
More info needed. Do you have nat gas?
every year i plan to buy a heater and get a 220 socket installed...then i just plug in a couple of small space heaters i have and they seem to take the edge off enough to make working in the garage in winter acceptable...not warm, but warm enough...my fiscally reasonable approach thus far...
Pinup calendars.
Male/female or whatever gets some heat in your garage.
Michael 1997 E36 M3 Alpine White 1996 993 Coupe Midnight Blue/Grey Past Rides: 2005 997.1 2S 2001 Audi S4 1989 Ford Probe |
Through wall heat pump, like a motel room.
Needs 220v. Heats and cools - both reasonably efficiently. |
Just heat, or would you like cooling too?
If both, get a mini-split system
Although many of the previously mentioned methods may have sketchy efficiency ratings, I chose to use a 80K BTU Reznor power vented natural gas unit heater mounted in the far corner of the 40' x 36' garage. It is hooked to a manual thermostat that usually is set to the lowest setting to keep the water lines from freezing and will maintain 45 degrees in sub zero temps for several days. When I want to work out there, I bump the t-stat to 65 and in 15 minutes it is toasty warm. The power vent allows the vent to be run out the side of the building and no need for a flue. Gas bill in the winter is about 30 bucks a month with half of that being surcharges as the gas itself is cheap. Very happy with it.
I use a multi fuel torpedo heater from Home Depot and usually run diesel in it as it is cheaper than kerosene. I usually turn it on an hour or so before hand pointing it at the tool box to heat up all that steel. Once the garage warms up, I vent the garage to rid fumes, and use and use a small electric heater to maintain. It also helps to run a few errands in one of the cars before hand, and then park it in the garage.
Dave |
