#71
Unbelievable work. Thanks for sharing.
#72
I wished you lived closer! I would so love to watch you do this work. Amazing.
#73
Thanks for the nice comments.
Yes, I use a MIG welder. For the spot welds I pre-drill the sections and use the MIG welder. Like this one. ![]() I think this is much cleaner as just weld along the edge of the new parts. I have one more update this weekend, and then I have to take a quick break, because I have to do the coolant pipes on the Cayenne. Cheers Engelbert
#74
Thanks, great work! Look forward to you posts!
2024 Lotus Emira FE V6 Manual 2005 Lexus SC 430 2007 Turbo - sold in 2023 1966 912 - sold in 2022 2005 BMW X3 - sold in 2022 1975 Vette - sold in 2015 2004 Cabriolet - sold in 2013 1977 924 - sold in 1991 |
#75
Here is a little update:
Cut out some of the bad sections on the left side rocker section. ![]() Making and fitting in a new piece. ![]() Here is it welded in and cleaned up. I also had to cut out a small section of the fender mount section. ![]() Next, I want to reuse the door post, since it was in good shape. Cleaning up and the crap from the backside. ![]() As well the metal from the rear quarter panel. Cleaned and blasted to be fitted back in. ![]() I also cleaned up all the crap under the quarter panel. ![]() Here is the mess that came off. ![]() The old and new Rocker support. The old one looks like somebody beat the $hit out of it. ![]() For the front I had to make a new piece, based on a picture I found on the net. ![]() Now things coming back together, just for fitting for now. ![]() Rocker is on as well the inner. All with sheet metal screws for now. ![]() Fitting the new section of the quarter panel, and found that it's a bit short at the bottom, so I have to add a piece. ![]() I also had some issues at the top. So I had to slot it and fit. The other side was better, anyway, still better then making it from scratch. ![]() Once I got it all aligned, it was tiome to take it all back apart and start welding in the bottom piece of the door post I made. ![]() Next is the inner rocker to weld in. ![]() Then the Jack support. ![]() The new rocker support is next. ![]() Looks like I'm ready now for the outer rocker. ![]() ![]() The outer rocker is welded in now. ![]() Now I can go and extend the bottom piece of the quarter panel section. ![]() As well the top section I had to slot and fit. ![]() Getting there, the piece is almost done. ![]() Done, next some more details to do. ![]() Cheers Engelbert
#76
Great stuff!
#77
You are truly amazing at metal work Engelbert!
“When I was born I was so ugly the doctor slapped my mother.” – Rodney Dangerfield Bill C "aka" Catdaddy - The Catfather - Current: 1980 911sc 2019 Ford Raptor 1987 Mercedes 560sl ------------ Sold: 2011 BMW M3 2000 996 C2-IMS 2 Row, RMS Update 1986.5 928s 1987 944 16v 1973 911t 1969 911t "My first car"!! 1969 Westfalia Bus 1973 Volks Superbeetle |
#78
Really nice work, thanks for the details. When fitting the outer rocker do you hold it in place with screws or clamps and fit the door?
#79
I noticed the black pain on the inner rocker. Do you do some treatment to the inside of these panels before you close them up?
And thanks for this great story!
#80
Awesome work.
2014 Mazda 3 DD 2015 Cayenne Diesel 2016 Spyder |
