#61
Thanks to all....I have definitely been schooled. At least now I understand its all about the moisture, more than anything else. Dry is good.
Now I'm curious if anyone has ever tried using a vacuum pump to evacuate the tire before refilling with dry air, nitrogen, etc.....
#62
I've never tried it, but the trick might be knowing when to stop. You'd want to get as much air out as possible, but there would be a magic [or tragic] point where you pulled enough vacuum to break the seal on the rim. Not much fun after that, I guess.
