#621
Grab the base in a vice and the nut/collar in the pipe wrench. Spray some PB Blaster into the underside of the nut. You might need to heat it with a torch and/or apply more muscle. It's probably crudded up with years of crud.
#622
Do you have another nut to hold the bilsteins in once you get the konis out? Or do you have to reuse that one? I could prob make you a tool, but it'll be Sun eve/Mon before I can get to it.
#623
The Bilsteins have their own nut (and it takes a spanner or can be hit with a hammer and chisel), but I hope to sell the Konis so don't want to just cut that nut off if that's what you were thinking about.
#624
You can order parts for the kioi's on line, search is your freind. BTW I don't think koni uses inserts so internal will likely have little resale value... get on with your project!
#625
but I hope to sell the Konis so don't want to just cut that nut off if that's what you were thinking about......
Now we're at the root of the issue. |
#626
a big pipe wrench will take that "nut" off easily. I had those apart back when it was my car.
go to HF and by the biggest freakin' pipe wrench they have and you'll be good to go.
#627
#628
ther's going to be a lot of oil in there so keep that in mind. Lucky, was there a "cartridge" in there or just oil, seals and the like?
#629
Last night, Andrew and I put in the seat, completed mounting of the DME and relay (tried turning DME over but no room for harness below it, so I'll fab a cover to keep it dry).
Taking advice of others here, this morning I used Kroil, heat (lots of heat), a very large pipe wrench, and a dead-blow hammer and got both Koni inserts out, Bilsteins in, and suspension done (with Ben). Drove to TR's to get the CV joint backing plates, then Andrew, Ben, and I put them on. Adjusted height of car to just below Euro (25" F, 24.5" R). That suspension is STIFF! Try to shake the car to settle the height, and it doesn't move at all. We adjusted the clutch and clutch cable, attached the gas pedel, and torqued everything up. And here we go (this is from tonight): Not all the fuses are in, which explains the single headlight, but there is a fail in here. I'll post the fail tomorrow, after Ben and I fix it...
#630
Current to-do list:
Electrical:
