#41
#42
I've tried the hairspray thing and it does help but not eliminate slippage for me. Wirebrushing/cleaning/scuffing all part of the process. Myers Tire Supply sells this stuff called Slip-Tac which is supposed to help as well. I have to use something as a lube while mounting the tires on my machine. If I don't, sometimes the rubber binds and can chunk/tear the inside of the bead where it seals. I have often thought of just balancing the wheel without the tire, mount the tires, rebalance and anything less than an ounce or two just not worry about it since sometimes the tires will be 180 degrees off the original mount position by the time they wear out. I guess the problem lies from the CCW wheels being so smooth on the bead surface. Weird though, even with the tires rotating I have never had any bad vibrations from a tire moving around on the rim.
#43
Slip-Tac did not work for me; maybe you'll have better luck.
At 180 degrees slip, the weighted wheel/tire is about 200% out of balance (if it stabilizes there, it would best to remove the weights); surprising that doesn't cause very noticeable vibration, but if it doesn't then maybe the answer is to skip balancing the tires altogether!
Previous: 2010 911 GT3 1993 911 RS America 1992 911 C2 Targa |
#44
#45
Did it work? (Not that I've had this problem - probably don't drive hard enough...)
| Special Activity: May 14-15 DE | Eric S | Track Talk | 5 | 05-05-2005 10:50 PM |
| 2005 tire thread | cmartin | Porsche Technical Discussions | 10 | 02-22-2005 10:13 PM |
| Toyo Tires | racer | Miscellaneous Discussions | 12 | 01-11-2005 03:40 PM |
| Wheel and Tire info. | Parenn911 | Porsche Technical Discussions | 20 | 12-12-2003 02:39 PM |
| Tire Tread Blowout Today | Doug E | Miscellaneous Discussions | 4 | 02-26-2003 05:04 PM |
