944 Suspension Refresh - Page 5 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 944 Suspension Refresh
Old 08-14-2012, 03:24 PM
Originally Posted by APKhaos View Post
Never seen one. Most go with the stock trailing arms, which are pretty much bombproof, and coil over setup.
Was asking about the spring plate not the trailing arm. But I get the idea. Even a 935 spring plate (on a 911) retains the stock trailing arm.
Is this just an area where the 944 is less developed aftermarket (than a 911)? Are inner camber boxes possible on a 944 like a 911 (which don't just provide camber adj but allow raising the roll center and messing w/ anti-squat) or does something like a gas tank get in the way? Im guessing full-tube frame 944s dont keep the stock pickup points.
I always found it interesting that people shun poly bushings on the inner joint of the trailing arm because they need to twist in 2 dimensions but then do basically the same thing w/ the outer bushing.
1984 930 - 3.6L
Old 08-14-2012, 03:33 PM
Originally Posted by Potomac-Greg View Post
..... As confirmed this past weekend, the car still hauls ass under new ownership!
It was funny during one of last weekend's sessions. I was riding with John, and as the SRF went by us, I said "He used to be a 944 driver, too." And John replied, "Yeah....this was his car."
Old 08-14-2012, 03:44 PM
Originally Posted by ausgeflippt951 View Post
Controlled four-wheel drifts through T10 @ SP? I just got to experience some of that action this weekend. It's like an adrenaline shot straight to the heart.
And 9. That's a good assessment.
It does.
It was funny to be protected by my old roll bar again as well.
Old 08-16-2012, 11:36 AM
racer's Avatar
racer racer is offline
racer
I am going to go back and say, keep it simple.
Adjustable koni's all around and learn to Drove. FWIW, i recall beating the young novice (OP) at AX in my Bone Stock (suspension, street tires) 944 by several seconds. That's an eternity on a 45-60 second course.
Spend the money on the seat time. Then some more seat time.
The more seat time you have, the more you will undestand what improvements you want to do next.
Maybe you will decide you want something quicker (S2/Turbo/Boxster/911) anyway.
Dave
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 08-16-2012, 11:56 PM
ruffyz ruffyz is offline
ruffyz
Now this idea I do like. Just need a hacksaw and some guts. Have there been any stories of hacked struts failing? If I go to heavier coil overs will I need/be able to get perches?
Old 08-17-2012, 10:44 AM
jsheiry's Avatar
jsheiry jsheiry is offline
jsheiry
Take a look at Paragon Products website, or talk to Jason at Paragon.
He sells kits for exactly what you talking about, when you move to 2" or 2.5" diameter springs you need to buy new perches anyway. He sells a kit for this that makes the strut an adjustable ride height perch with a top perch to match.
Not saying he is the only one but certainly a great wealth of knowledge as he also races a 944/968 chassis.
Ground Control sells some similar kits and they are knowledgable but not nearly as specific 944 knowledge that you get from Jason.
John
92 968 Maritime Blau (few bullet holes...rescue in progress)
94 968 Polar Silver Cab (prepping for sale)
95 968 GP White Wifes DD
93 968 Amazon Green Cab
94 968 Iris Blau Cab
92 968 Lagoon Green
94 968 Polar Silver M030
87 944 NA track/de car
72 Signal Orange 914 survivor
Old 08-17-2012, 10:59 AM
ausgeflippt951's Avatar
Shock Whisperer
Jason's a great guy. Actually owns a real 968 Turbo RS.
Keep in mind that the stiffest spring you can go with on a stock strut is 250#, after which you'll need the coilover perches.
The Koni cut-n-guts are a great way to go.
Collin M.
I wear a cowboy hat.
'06 M3: hers.
Old 08-17-2012, 11:28 AM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
^ +2 on Jason. He knows these cars well, and has good stuff.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 08-17-2012, 12:10 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
^^+a gajillion Jason will not steer you wrong. Tell him what you want and he will set you up. He's actually talked me out of stuff. Very honest and stands behind everything he sells. Tell him Steve in Md sent you. I've probably made the payments on his Shelby for the last couple of years....
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 08-17-2012, 07:46 PM
they do but to a further extent. some folks think hard plastic bushings bind, stress other parts and also fail quickly.
I have seen a few well set up 944 tubs that included changes to the inner pickup points.
