#31
He forgot to install the fuse cover!!!
...more than likely just showing off how nice the fuse block is. What was used to recondition those pieces, I'm sure all of us would like to know! Great attention to detail.
'64 356 SC '73 914 2.0 (2.8/6 conversion in progress) '65 Ducati Falcon 80 '67 Ducati Cadet 100 4-speed ‘19 Q7 Gone but not forgotten: ‘19 SQ5 - totaled while parked in front of of my house '02 S6 Avant - trans blew, but rebuilt as a 6-speed by new owner '99.5 A4 2.8QT - tree fell on it after 20 years ‘74 MB 280C - traded for paint/rust repair/6-conversion mods on the 914 |
#32
Cheers Engelbert
#33
The ignition box. I tried to disassemble it and take the guts out to grit blast it, and noticed it will not come out that easy. So, after I removed the back cover, I put several layers of duck tape inside to seal it up, and put the cover back on for blasting. After that I just sprayed a clear cote of plasticoat on it so the aluminum will not start to corrode. Will see how it's going to last. The other parts I just scrubbed with oileater, electrical cleaner, scottsbright and so. Cheers Engelbert
#34
I made some progress.
All the suspension parts are removed. Got some parts blasted. ![]() And Powder coated. ![]() ![]() ![]() Here the struts and hubs. ![]() The hubs have quite some corrosion, and I think I need to find some good once. ![]() Here are the struts after blasting. There were Koni insetrts installed. I need to see if it would make sense to rebuild them, or just put a set of Bilstein HD in. ![]() I started to get the undercoat off which was sprayed on the car, what a mess. I got a good tip about using Kerosine. It works but slow, however, that's better than anything else I have tried. Here are a few sections I cleaned up. I sprayed it on with a spray bottle, and then used a brush to loosen it up, and wiped it off with rags. I put a plastic on the floor and some oil try on it. ![]() It looks like the factory chip guard is light gray. ![]() To be continued Cheers Engelbert
#35
Nice progress!
#36
Someday, I want to buy a car that Englebert restored.
Job is done right. Impressive.
----- Ken 1988 911 Carrera 3.2 (1995 911 - gone) 1997 Spec Boxster - #121 (gone) 2004 911 GT3 2022 Mini Cooper S 2017 F250 |
#37
Great work !
I also been removing undercoat that was applyed on my Citroen CX chassi, its a messy job , I will try Kerosine next , thanks for the tip On mine they spray everything After a week removing crazy amount of undercoat I re apply Por15 undercoat and looks really nice Keep up good work Antonio
2007 997 Turbo 1990 G Wagon Diesel 1990 Porsche 964 C2 G 1985 Citroen CX GTI 1988 Citroen BX GTI 1976 Vespa GTR 125cc 1970 Citroen Mehari 1968 Citroen ID 20 1965 356 C |
#38
If you follow-up with a pressure washer or hose hooked to hot water it comes right off! Paul-
#39
Sounds like you guys need a steam cleaner
#40
how big a steamer cleaner would you need for a job like this??
Antonio
