#31
Just an add on to this thread. The DME relay evolved from the "Double Relay" used on L-Jet injected 914s. But it evolved badly. In 35 years of running an L-Jet 914, I have only replaced the "Double Relay" once.
And I have had lots of experience with DME relays. I used to work on Porsches for a living. I got lots of 944s, 911 Carreras, and BMWs towed to the shop with no start issues. First thing I did was to replace the DME relay with a test one. About 90% of the time that fixed it. So I made a replacement. I took a DME relay and stripped the base of everything but the pins. Then I got a pair of sockets for a standard Bosch square relay. With a little wiring, I was able to build a plug in replacement for the DME relay that used standard Bosch square relays. When I put the 964 motor into my 914, I just rewired the harness to eliminate the factory DME relay, and put in a pair of Bosch solid state relays. I should never have a DME relay issue. If it will help everyone, I can workup a wiring diagram that will show you how to redo an old DME relay to use a pair of standard Bosch relays. Clay Perrine |
#33
Cheers Engelbert
