#311
I just purchased on of these on sale from SWAG. I agree with Ed, it works well.
#312
GEARWRENCH 1/4" Drive 90 Tooth Long Handle Teardrop Ratchet 6" - 81028T
I'm a sucker for a nice ratchet. This little thing feels good in hand and the action is very smooth.
#313
Looks like a nice tool.
#314
I bought this little guy out of frustration and it has proven its worth.
https://www.amazon.com/dp/B08D6YDQNH...roduct_details I was working on the wife's Audi A3 to replace a servo motor on the HVAC system that had crapped out and air was not going where it needed to. The servo in question was way up in there and attached with two torx bit screws. It was impossible to get anything thicker than about an inch on the screw. This little fella allow you to put just the torx bit in it making it nice and thin. By holding it with your thumb and middle finger and with your ring finger in the loop on the end and your little finger outside, it won't slip out of your hand and you can get enough torque on it to loosen the bolts. Once loose, the thumbwheel is used to loosen the screw quickly. Same for reinstallation since the ratchet can be reversed with the lever. Great little tool for working in tight spaces. Comes with a 1/4 socket adapter as well.
#315
https://www.amazon.com/AGM-Products-...4184364&sr=8-3 Looks like a nifft6 idea for a DIY project too.
#316
Barry 25 Carrera cab 21 Macan S |
#317
Geeze Barry, it sounds like your offering.
#318
So, I wanted to learn to do some welding and there are a lot of cheap welding equipment on amazon.
I bought this guy on sale for $48 bucks a few weeks back. https://www.amazon.com/dp/B0B2QQW3WZ...t_details&th=1 Have not even opened yet since I don't have any other accessories like (helmet, gloves, etc). Before I go any further, what do you think about these?
#319
Turning good track cars into other people's headaches since 1990 Denis Jenkins (PCA'86) 95 318ti S54 95 318ti CS S50 02 325XIT 02 330i 98 328i 71 911T 70 Karmann Ghia, 96 f350 7.3 99 StarFlyte 13 C-Max Gone 4 356's,1 996, 4 911's, 1 912, 2 Boxster S, 5 914's, 3 944's, 3 951, 1 924S, 4 95 m3, 03 M3,95 Ti/CS. 97M345, 84 rx7ITB, ITB gti 21, ITB GTI 48, 89 325is s52,07 Z4 coupe, 69 Charger General Lee, 2 66 Cadillac verts, 1 68 cadillac vert, 87 RX7 ITS and others |
#320
Does that unit accept gas? if not the tig welds will need excessive heat for it to fuse/melt together and will be very porous. I failed my welding tech cert 2x due to porosity - gas pressure too low the first time and lack of penetration - heat too low the second. Luckily third time was a charm. I find myself gravitating to the mig for most mild steel and the tig for stainless and aluminum.
Al W. 2001 911 cab |
