polish engineering... hey, no laugh! - Page 30 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » polish engineering... hey, no laugh!
Old 07-10-2012, 06:32 AM
Feliks's Avatar
Feliks Feliks is offline
Feliks
http://enenews.com/high-radiation-le...rods-fukushima
Whether the IAEA supports still so cooling reactors, or changed the sentence. ??
Andrew
Old 07-16-2012, 12:04 AM
Feliks's Avatar
Feliks
Originally Posted by Feliks
And my animation, showing what you can do in 4 Fourth swimming pool in Fukushimie.
You need to build a new building, to the basement of the reactor building to insert with three new reactors, only to store the fuel. They manage any guarantees when possible earthquakes.After filling all the water also will be a guarantee of the & span settlement.
Andrew
Old 07-18-2012, 07:49 PM
Feliks's Avatar
Feliks
Whether engineers will pretend that the atomists still do not know the new inverter UPS Technology on batteries, which in the case of a power failure, it is ready within fractional seconds to the provisioning of the full effect of emergency systems ???
Of course, some diesel then can long function.
But I think, with this reason for savings, because and so nuke is already insanely expensive.
http://www05.abb.com/global/scot/scot235.n...chure_rev_c.pdf
Andrew
May repulsion to techniques derived from green energy does not permit widely its integrity in nuke ...
Old 08-08-2012, 07:09 PM
Feliks's Avatar
Feliks
Monument to the victims of the earthquake in its epicentre in Tashkent. You can see clearly the huge cavity, in which the trees are growing, and despite their vertices do not protrude above the ground of the monument, the cavity is approx. 50 m depth.
And talk to someone it does not appear that build the atomic power stations on earthquake-resistant, ...Jan Christian Andersen Fairy Tales. ...
I have seen. I recommend a trip atomist engineers in particular.
Andrew
Old 08-17-2012, 10:21 PM
Feliks's Avatar
Feliks
In order to provide the reactors in Fukushime from the bottom you have the mechanical tunnel.
Then insert the two meters in diameter with 20 tubes. , Do the holes from the top and side, and on the bottom line fire resistant ZrO2. For large pipes enter the small tube to remove radioactive leaks or cooling corium had reached there...
http://www.herrenknecht.com/fileadmi...B_09-12-21.pdf
http://www.herrenknecht.com/fileadmi...B_08-10-29.pdf
Certainly not the cheapest, but it will give guarantees that the radioactive materials do not enter the land and ocean
Regards Andrew: Cool:
Old 09-05-2012, 10:19 AM
Feliks's Avatar
Feliks
Can to remove scrap metal from the reactor 3 can use these electromagnetic grippers?
Also for attaching various devices and cameras probably would be useful..
Andrew
Old 09-23-2012, 08:12 PM
Feliks's Avatar
Feliks
Whether, if the sprayer to the treadmill, for example, a car, it will be more supportive of animals?
http://en.wikipedia.org/wiki/Horse_mill
Andrew : Roll:
Old 09-26-2012, 09:28 PM
Feliks's Avatar
Feliks
I wonder if to ask if these two smiling at us men to graciously evacuated their asses out of this car, it would be possible instead of carriage them to produce some electricity for us? Since drivers are not needed, because the car is harnessed to the treadmill and drivin in circles .. But one thing is certain, that such a vehicle driving the external energy, we will have the wind, regardless of the weather ... AJ is here the energy produced is sufficient to maintain the treadmill speed, it will be good .... And maybe even a few kilowatts for us is for our use ....
And it is always, regardless of the weather ... I do not need to go to the desert to breaking records. This can be done on the treadmill near the house...
http://news.discovery.com/autos/how-...rk-111207.html
Andrew: D
Old 09-27-2012, 06:15 AM
Feliks's Avatar
Feliks
Finally, heavy equipment, the 21st century as far as technology began to be used ..
Andrew: D
Old 09-27-2012, 09:35 AM
Feliks's Avatar
Feliks
http://www.rcgroups.com/forums/attac...hmentid=777461
Of course, the fuel will be coal dust....
Andrew: Wavey
Originally posted by Anth
Of course
I hope you will also agree with this, teeth were the least moving parts. The 5 MW windmill should be placed. Mounted on the ends of the arms jet frame. (ends reach such a large fan wheel 1 Ma), so the jet frame will fit well ... It will be a "small" treadmill
http://en.wikipedia.org/wiki/Ramjet
Andrew: D
