Soft Sockets & Lug Torque - Page 3 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Soft Sockets & Lug Torque
Old 06-01-2005, 11:40 PM
BW911's Avatar
BW911 BW911 is offline
BW911
That's easy for you to say, Kurt.
Bill W.
Bill W.
'88 Carrera
Old 06-01-2005, 11:56 PM
Originally Posted by s5uewf
Steve, I have a soft socket and I shattered it after just a few uses.
Ditto. My soft socket did, however, turn into a really nice regular 24mm deep well socket. Not that I've ever needed a 24mm deep well, but when I do - I'm ready.
Old 06-02-2005, 08:09 AM
Kurt, if torquing properly is stretching to induce an acceptable clamping force - could we test by measuring the length of the torqued fastener,
Assuming we knew the original length?
Done all the time in high end apps.
If so, we just need you to design a laser/optical or other type measuring
Device. Or, perhaps some type of seismic device which can calculate
Length based upon echo results so you don't have to be able to 'see'
The far end. ?
X-ray machines with measuring devices are used in nuke and military apps to measure and inspect.
How about this for an idea? You make a bolt with a very tiny hole drilled through the center and install a thin wire in it. Attach the wire at the insert end and have a red mark on the other end that sticks out of the bolt head. Tighten until the red mark goes flush with the top of the head and you have a correctly stretched bolt. This even makes up for different temp installs as the wire expands along with the bolt.
Originally Posted by Parenn911
Originally Posted by ras911
Kurt
Did you have your meds today?
ROFL
Someone explained the joke to you didn't they?
Old 06-02-2005, 10:01 AM
Chronos's Avatar
Chronos Chronos is offline
Chronos
What is all this talk about tightening lug nuts? Isn't that what the mechanic is for?
'00 C2 Slate Grey/Boxster Red
'13 BMW E70
'13 BMW F10
Old 06-02-2005, 03:46 PM
Kurt
ROFL
What joke We really want to know
Torque and the HF Torque Wrenches VaSteve Porsche Technical Discussions 17 12-21-2004 06:34 AM
Any have the Hazlet open sockets? Rick Lee Tools Needed/For Loan 0 05-14-2004 09:49 AM
73 on the track - broad torque, or peakier & more HP Jim Richards Track Talk 4 03-08-2004 07:19 AM
torque specs Mackpipes Porsche Technical Discussions 5 10-10-2003 08:16 AM
