#21
Certainly does not sound like the clutch itself.Go with the checks above.If its slipping put it in high gear 4or5 drop down to 1500 or so rpm and then gas it hard.Slippage will be obvious. If its a problem with the fork bearings, try doing a fairly quick take off from stop clutch in.If it then slips, your fork is not releasing. Bleeding clutch slave cylinder never hurt and is a good idea.
Dirk |
